Engine Mount Bolt Pattern
Old Nov 10, 2005 | 11:29 AM
JNeely's Avatar
JNeely
Over the years of 460 production, was there ever a change in the bolt pattern for the engine mounts?
I have a 1971 429 CJ that is really close to being finished, and I am going to put it in my 73 250 hiboy. Someone told me the easiest way to do this swap was the purchase of 80's truck mounts and 400 frame horns. I had some of the frame horns, and went to NAPA for the mounts. There are two studs protruding from the mount, so the plan was to cut one off. However, they don't bolt up to the block! I thought all blocks were the same, so is there a possibility I've got the wrong mounts? What's goin on here?
-Any help is appreciated
Old Nov 10, 2005 | 03:12 PM
garbz2's Avatar
garbz2
The 80s mounts are entirely the oppsite of what is needed in a mid seventies application.... Dont watse time and money tracking down what will work...
Check With BOTP or National parts depot.. they carry a set of mounts at reasonable cost.
The stock ford mounts used a 3 section cross bolted perch and don't look anything like a modified mount.
Garbz
Old Nov 10, 2005 | 03:28 PM
banjopicker66's Avatar
banjopicker66
Garbz is right.
I put a 460 into my '66, and used the perches and mounts from a '77. You can use the 460 perches From any F-250 or lower truck up to '79.
The block, though, is the same up to at least '86. I used '77 mounts and '77 perches on an '86 block to put it into my '66 F-100, and it all bolts right up, no modifications required. Even the transmission crossmember bolted up like stock.
Old Nov 10, 2005 | 03:47 PM
garbz2's Avatar
garbz2
John
Only discrepency is in the four wheel drive... those mounts dont even come close to looking like the 2 wheelers we are used to eye balling.
L&L has the safest mounts.....along with hedders to fit in the four by four applications.
BOTP and NPD offer a similar unit to the L&L at a cheaper cost.
Garbz
Old Nov 10, 2005 | 03:52 PM
banjopicker66
AH, yes.
The inevitable 4x4 exception!
OldHarley
Dec 16, 2019 02:25 PM
Jobless
15
Jul 10, 2019 06:02 PM
FractureCritical
Dec 10, 2016 05:53 PM
fourboltmain3401
Apr 20, 2016 08:20 PM
stumpy2
22
Feb 3, 2003 04:07 AM
