Timing
Old Nov 4, 2005 | 05:42 PM
mwk's Avatar
mwk
Timing
My timing was advanced and I set it back a bit, I don't think that was such a good idea. Went to move the IP back and it won't go, will not turn back. Am I missing something here, my bolts are loose too.
Old Nov 4, 2005 | 08:30 PM
wh336fire's Avatar
wh336fire
It will be hard to move with the injector lines on . Haven't tried moving it myself with the lines still on , but have read that it is possible .
Old Nov 4, 2005 | 08:48 PM
PLC7.3's Avatar
PLC7.3
Not sure if your IP has the square block on the front of main body so you can use a wrench to assist with movement.......
Old Nov 5, 2005 | 05:22 AM
mwk's Avatar
mwk
Is it under the oil fill cover? I'll pop that off later today.
Old Nov 5, 2005 | 06:00 AM
bilder12's Avatar
bilder12
Not under the oil fill cover ! that is just the mounting bolts to the drive gear under there. The timing adjustment is all outside. loosen the 3 nuts. it is tuff to move the pump but it will go enough to make a difference. If you can get hold of a spanner wrench you can move it that way, the top to the passenger side to advance it. A little movement is a lot of advance.
77 2wd
34
Aug 9, 2012 04:21 PM
Curt's05
Apr 30, 2012 08:24 PM
guitarblues78
Modular V10 (6.8l)
Sep 16, 2008 01:11 PM
tank55
2004 - 2008 F150
13
Apr 18, 2006 08:43 PM
76_F150_390
Oct 1, 2002 04:55 PM
