Aerostar Ford Aerostar
Darn oxygen sensor
Old Nov 1, 2005 | 11:25 AM
Ray_N's Avatar
Ray_N
I'm going to take it to father in law's place.. ramp it up, and use and impact gun to take it out. If not.. i'll cut it out and weld a new pipe back in myself...
Old Nov 1, 2005 | 12:09 PM
Bear River's Avatar
Bear River
Former ******
Ok, good luck. Just try not to change its overall position.
Old Nov 1, 2005 | 12:14 PM
copper_90680's Avatar
copper_90680
What impact gun are you going to use? A .44 Magnum?
Old Nov 1, 2005 | 01:24 PM
96_4wdr's Avatar
96_4wdr
got access to air impact chisel hammer, try at base of O2, may loosen some of the rust, if you have enough room to work
will at least make you feel better after the O2 has some heavy dings in it
why the O2 sensor manuf.'s don't use a stainless steel compression seal washer instead of the cheap steel washer must be a bean counter eng. decision. road salts and chemicals build up around and in seal washer, steel against steel corrision with heat, guaranteed big problemo
they build the sensor case out of stainless but too cheap for 10 cent SS washer? go figure
bean counter engineer must be the same one who designed location of O2 sensor wire cable sockets on 96 AWD
Old Nov 1, 2005 | 01:35 PM
copper_90680
96_4wdr:
As an engineer, I take offense at the "bean counter engineer" comment. We're not bean counters, we're just incompetent at times
Old Nov 1, 2005 | 01:44 PM
96_4wdr's Avatar
96_4wdr
copper, i know you are not the one who designed the booster rocket seals or the fuel tank foam on the Shuttle, but there is a bean counter engineering group out there that is responsible
at least a stuck O2 sensor will not kill a person
Old Nov 1, 2005 | 02:18 PM
copper_90680
That was a joke 96_4wdr. I wasn't the least offended
Old Nov 2, 2005 | 06:16 AM
tomucen's Avatar
tomucen
I had the same problem recently.
I used a ring wrench with a long pipe extension and it still took me a lot of force to get it moving. But: it only worked when I had a firm stand under the car (lifted up in a DIY-shop), not when it was jacked up in my garage.
Old Nov 13, 2005 | 05:36 PM
PaulRR72's Avatar
PaulRR72
have heard that if you heat up the pipe, dose it with cold water for two or three cycles this will also crack it loose. have never tried this as the bigger pipe wrench worked for me!
Old Nov 14, 2005 | 05:14 PM
vintageant's Avatar
vintageant
On the candle wax method mentioned above, I believe it's bee's wax not candle wax which is primarily parafffin based.
Yesterday I had the devil of a job getting #3 spark plug out and finally jarred it loose by using a 4 lb hammer on a piece of 2" x 1" wood against the ratchet.
It will come loose! Just don't give up!
77shortbox400
Oct 27, 2019 12:24 PM
jimmyhighrider
Apr 30, 2012 08:18 PM
jimmyhighrider
19
Apr 29, 2012 02:26 PM
tjc transport
New Jersey Chapter
45
Aug 9, 2008 10:09 PM
scalhoun
Feb 10, 2001 09:40 PM
