351 rebuild
Old Oct 20, 2005 | 08:38 PM
dino360's Avatar
dino360
Cool 351 rebuild
I spun a bearing on my 93 bronco 5.8. I am now debating dropping in a rebuilt engine or rebuilding mine with a little more performance than stock. It is a daily driver with 170,000 miles and a 4inch lift with 35's. I have never rebuilt an EFI so I am trying to get ideas so I can compare cost and efort between the rebuilt or rebuilding it myself. Thanks for any suggestions.
Old Oct 20, 2005 | 08:49 PM
captainkirk's Avatar
captainkirk
Go ahead and rebuild your 351 for a little more performance. It may seem intimidating being EFI, just make sure you clearly mark all of the connectors. It should be just as easy as rebuilding a carb'd 351. While you have the motor out, go ahead and slip a cam in in it and maybe higher compression pistions. You won't regret it and not only will you save money compared to buying another engine, you will gain the experience of working with the EFI. As far as price goes, if you find a competent machine shop $650 dollars should get you the following: Everything cleaned and crack tested, New pistons, new rings, Full engine gasket and bearing set(including main seals), new valve springs, guides, seals, retainers, all block machining, and the pistons installed on the rods.
Kirk
Old Oct 20, 2005 | 11:50 PM
pcmenten's Avatar
pcmenten
You can hop up the original short block and make a big difference in the way that engine works. Retro-fitting a roller cam using 5.0 HO parts is one thing you can do. Since you're looking at fixing the crank already, you can get a stroker crank, use stock 351 rods, and stock 302 pistons to make a 392W. The crank is pretty cheap on ebay and considering that you need crank work, it's almost free to make a stroker.
Be sure to zero-deck the short block. Degree the cam. Hypereutectic pistons are your best bet.
Old Oct 21, 2005 | 02:31 AM
stevef100s's Avatar
stevef100s
All good info. Sorry to butt in, but I was wondering how a guy from Idaho picked up an Aus. 351, and if it's running yet (in what)?
Old Oct 21, 2005 | 11:03 AM
Kemicalburns's Avatar
Kemicalburns
well he cant stroke running speed density. so that option is out with unless converting to mass air.
go with compcam 35-255-5 great speed density cam with good torque. if you can get your heads worked over or find a set of gt40 heads not gt40Ps that would be an even better upgrade. shoot for a compratio of 9.5 this will still run on 87. headers and a free flowing 3" exhaust single of course will help out lots.
if you can afford to get the edelbrock efi truck intake do it. great gains also a bbk 56mm throttle body will round out your build and really give ya what your looken for.
by the way what gears are you running with those 35"s
Old Oct 21, 2005 | 10:18 PM
pcmenten's Avatar
pcmenten
Red face
Hi Steve. Phil in Portland, Oregon (ausheads) was selling the block on ebay. I also got two iron 4bbl intakes for 2V heads. I'm still gathering the parts for this engine; truck (rear sump) pan, Melling oil pump, front cover, Oz heads, Holley spreadbore carb, roller cam setup, distributor w/Pertronix. Need crank/rods/pistons, probably a stroker setup.
I'm currently working on a 292/FMX and a 312/T85/od but the Cleveland is next. Going into a 53 Studebaker 1/4 ton.
Old Oct 24, 2005 | 07:25 PM
donnor's Avatar
donnor
stroker & speed density
I may beg to differ with the above, Two years ago my son & I rebuilt a 94 302 as a 347 stroker. We installed it in his 92 Bronco and have had virtually NO problems with it - related to air management or anything else. We maintained his factory SD; changing only the location of the air temperature sensor from the lower intake (since the 94 intake did not have an opening for it) to the upper side of the air filter box - much the same as a factory MAF system.
He has found it to be very reliable with great gas mileage (for a V8) and a great deal more "torquey" in the low RPM band than the original 302. Performance seems to be on a par with a factory 351.
dn.
Old Oct 24, 2005 | 07:47 PM
dino360's Avatar
dino360
Cool
Thanks for all the input guys. I am running 4.10's with the 35's and wishing I had gone 4.56.
Old Oct 25, 2005 | 09:48 AM
Kemicalburns
dn.
what cam were you running. and how would the ecu make calculations running such a motor? if the cam kept its lobe seperation at 114* and the motor didnt lean out then its possible. but the computer cant compensate like a mass air ecu can. you couldnt have run anything larger then the stock 19lb injectors. so you also used a mustang upper/lower intake or did you continue to use the stock bronco intake? speed density cant calculate incoming flow so i cant understand that by moving the air temp sensor to the intake made any difference. do you have any pics of the install , not saying your lieing just want to see how its setup.
Old Oct 25, 2005 | 10:34 AM
Blurry94's Avatar
Blurry94
Many GEN 1 Lightning owners are running storked speed density applications, and custom grind SD friendly cams. Of course, there is aftermarket tuning that ties everything together.
Even so, you can't just throw a mass air kit on it and say it'll run. Mass air is not a "set it and forget it" type system. unless this is going to be a stock or very mild rebuild, it'll still need tuning to dial everything in properly.
Old Oct 25, 2005 | 09:52 PM
pcmenten's Avatar
pcmenten
dn.
I can believe this. SD has a 'base map'. I can believe that open loop mode wouldn't be perfect, slightly lean, but that closed loop would be fine. The ECU would detect the lean condition and adjust. Also, it remembers the mixture compensation for the next time. Good to know.
I've got an 85 Lincoln 5.0 engine that's probably going to be converted to SEFI, possibly a 331 stroker.
Old Oct 25, 2005 | 11:13 PM
donnor's Avatar
donnor
To air is human...
I would love to show pics, but the truck is in Tulsa with our son - he is a junior ME student at the University of Tulsa. However, on our next trip down I will try to snap some pics. The original 94 cam & injectors were reused; as well as the 94 Bronco intake. We were not sure if moving the intake air temp sensor would cause a problem but did not take note of the lack of a tapped hole in the lower intake until after we had the assembled engine back from the machine shop & setting back in the vehicle.
Any of you who have put a K&N FIPK on a MAF Bronco/F-Series already know that with this setup the temp sensor is mounted to a bracket that extends off to the side of the filter, placing the sensor out in the open in the engine compartment: Not even directly in the airflow path of the intake stream.
dn.
Old Oct 26, 2005 | 09:15 AM
Kemicalburns
that would be great. because i have never heard of anyone doing it this way. using the the stock cam and intake helped im sure. but that motor sure isnt to its potential either wouldnt you agree? if the combo is right it will work. but how many times do you think that happens hehe. thats why i try not to go there with some of these folks.
Old Nov 29, 2005 | 02:38 PM
donnor's Avatar
donnor
different strokers for different folkers
Touche', but the guys at our local (very reputable) machine shop told us that they had done a number of these type of rebuilds/buildups through the years without any problems so we felt quite reassured in proceeding on this course of action. All I know is that we have been VERY pleased with the results: Great mileage (16-18 highway, low-end torque not unlike that of a 351 (after all, we are at 347 c.i.), no problem codes from the computer, and a tailpipe that burns almost as clean as the one in my wife's 96 302 MAF Bronco - which passes the white glove test anytime it is administered!
dn.
xtal_01
Aug 11, 2016 05:41 PM
jjurva!
Feb 20, 2013 06:51 AM
ar29456
Apr 7, 2006 04:54 PM
lawnbiz
Apr 12, 2004 07:21 AM
oregon250
Jun 18, 2003 03:03 PM
