rebuilding tranny
Old Apr 5, 2006 | 10:51 PM
ar29456's Avatar
ar29456
rebuilding tranny
Hi I have a 94 explorer with the 4x4 I was just wondering if it is worth getting the tranny rebuilt
Old Apr 6, 2006 | 01:54 PM
mrshorty's Avatar
mrshorty
That's a hard question to answer for someone else, so I'll answer it as if it were my Explorer.
If this were my Explorer, I would probably say, "yes, it is worth getting the transmission rebuilt." This assumes the body isn't rusted all to heck, and that the frame isn't bent. Basically, the way I look at this question goes something like this:
option A) To repair existing vehicle, I will pay $2500 give or take to repair existing transmission. After repair, I will drive home in a vehicle with a known history and a known good transmission (at least as good as an A4LD can get). Kind of a gamble, because I don't know when the next major repair will come along.
option B) Sell vehicle as is (probably only get a few hundred dollars if lucky), put up ~$4000 out of pocket to get another '94 Explorer. Won't know history or have any other idea as to how the vehicle has been treated. More of a gamble, because, not knowing the history, it is harder to predict when the next major repair will occur.
option c) Sell vehicle as is (~$x00) and buy something newer with fewer miles. Out of pocket costs for this option can vary from ~$4000 for an older/higher mileage choice, to upwards of $50,000 for the latest greatest luxury SUV. Risk of future mechanical failure in this category varies widely, but is roughly a function of cost. At the lower end of the price range you will get an older/higher mileage vehicle. At the upper end you will get a newer vehicle with fewer miles.
A warranty can offset some of the risk. At the lower end, the warranty will add to the out of pocket cost. At the upper end, the warranty may be included in the purchase price. Depending on the specifics of the warranty, there willl be exclusions, limitations, and even deductibles, so a warranty is not a guarantee that you won't have to pay for a repair, just reduces the risk.
Whenever I've analyzed this kind of situation for myself, I almost always choose option A. I can't choose for you, though.
Old Apr 6, 2006 | 03:11 PM
ar29456's Avatar
ar29456
I will probly take option A because everything is in good shape and plus my friend is a transmission specialist and he said the master rebuild kit for it is $600 so all we got to do is the labor. thanks for all your help
Old Apr 7, 2006 | 04:54 PM
Exploder02's Avatar
Exploder02
Some might say to get a new or factory-reman from Ford.. don't! I had a factory-new 5R55W put into my '02 when the original crapped out @ 52,000 miles.. the "new" one failed the exact same way @ 70,000. It was rebuilt by the dealer tranny tech, and it works better now than even the original one did when I drove it off the lot. There's a lot to be said for hand assembly by a pro!
tomcolombo1990
1997 - 2003 F150
Dec 16, 2010 09:02 PM
SchaefferUSMC
Sep 4, 2010 08:11 PM
KaeJay
Sep 9, 2007 08:02 AM
f100guy
Apr 26, 2007 05:44 AM
