wiper switch problem
Old Oct 18, 2005 | 09:37 AM
HighboyMac's Avatar
HighboyMac
Question wiper switch problem
My 77 highboy has intermittant wipers. You know the type. Turn the **** left for intermittant.. Right one click from center is low...another click fast. Push the **** in and it washes. What has happened is that the low setting doesn't work. The high setting will work for a while then occasionally the wipers will stop mid windshield. Then they will start again.
My question. Does this sound like a dead wiper control switch....or ??????
Old Oct 18, 2005 | 09:54 AM
scottlane's Avatar
scottlane
I'd pull the switch and make sure the switch contact points are clean. Oxidation and corrosion can keep you from making good contact. I'd also check for good ground.
Old Oct 18, 2005 | 11:40 AM
Mil1ion's Avatar
Mil1ion
Sounds to me like a wiper motor ground or speed governor problem.
Does the Intermittent work ?
Old Oct 18, 2005 | 01:34 PM
HighboyMac's Avatar
HighboyMac
yes...the intermittent works beautiful. No issues there. It will work forever...just the steady on is having issues.
Old Oct 18, 2005 | 06:26 PM
User 71024's Avatar
User 71024
well intermittent just turns the low speed on and off, soI would say its the switch.
Old Oct 18, 2005 | 06:40 PM
JSPajak's Avatar
JSPajak
Is the intermittent switch easily available as a replacement piece? Who sells them?
Also, can an intermittent switch be replaced by a standard switch directly? Does anything need to be changed?
Thanks
John Pajak
61 F100 Longbed Unibody
76 F100 LWB
http://jspajak.tripod.com
Old Oct 18, 2005 | 06:59 PM
dakonthemountain's Avatar
dakonthemountain
The switch plugs into the same plug as the old (regular) one. I have done this. I got mine off of eBay.
Dak
Old Oct 19, 2005 | 12:40 PM
Mil1ion's Avatar
Mil1ion
To swap from Non-Intertittent to intermittent wipers ...one has to have the special switch AND the special Governor.
Check the tech articles for the procedure.
Old Oct 19, 2005 | 12:49 PM
77460f150's Avatar
77460f150
[QUOTE=JSPajak]Is the intermittent switch easily available as a replacement piece? Who sells them?
Thanks
John Pajak
76 F100 LWB
http://jspajak.tripod.com[/QUOTE]
Yes, the switch is easily available as a replacement part. Check out our sponsors, most of them sell the switch. I have found this switch in the National Parts Depot catalog on page 199 (part # F-17A553-7) at a cost of $54.95 each. I have seen these on ebay (used) once in a while too.
The two switches (standard and intermittent) are totally different and will not interchange. The standard switch does not physically have the intermittent selection available. It only has off,low and high. -Ed
Old Oct 19, 2005 | 01:15 PM
JSPajak's Avatar
JSPajak
[QUOTE=77460f150 The two switches (standard and intermittent) are totally different and will not interchange. The standard switch does not physically have the intermittent selection available. It only has off,low and high. -Ed[/QUOTE]
What I meant by interchanging, was could an intermittent dwitch be replaced by a regular switch without modifying the truck? I realize I would lose the intermittent function.
John Pajak
Old Oct 19, 2005 | 01:46 PM
Mil1ion's Avatar
Mil1ion
Head's up !
You have 60 minutes to EDIT your own posts.
Old Oct 19, 2005 | 02:29 PM
User 71024's Avatar
User 71024
John Pajak
Yes it should plug right in, I did it on my 70 stang which uses the same switch as the truck.
Old Oct 19, 2005 | 07:51 PM
Mil1ion's Avatar
Mil1ion
Eric, I think he means.... can he get intermittent wipers by replacing the NON intermittent switch with an Intermittent one.
The answer of course is NO..
You need the (Governor) speed control
Old Oct 19, 2005 | 08:29 PM
User 71024's Avatar
User 71024
"I realize I would lose the intermittent function."John Pajak
he knows
92 Black Nite
Electrical Systems/Wiring
Oct 22, 2013 07:25 AM
jsnbuck
Jul 9, 2012 09:34 PM
Blue and White
Jan 1, 2012 05:34 PM
jodaddy
Oct 31, 2010 11:16 PM
wyo_overkill
Mar 15, 2010 04:14 PM
