over charging?
Old Oct 16, 2005 | 03:12 PM
Rusty01's Avatar
Rusty01
over charging?
how can i tell if my alt is over charging on my 2001 f350 psd
Old Oct 16, 2005 | 05:27 PM
Bob Ayers's Avatar
Bob Ayers
Measure the battery voltage with the engine running at a fast idle. If the voltage is above 14.6V, it's overcharging.
Old Oct 16, 2005 | 08:10 PM
Rusty01's Avatar
Rusty01
it says that it is charging at 14.26 is that ok? and should it be charging like that all the time or does it stop charging from time to time or when it's suposed to charge?
Old Oct 16, 2005 | 08:20 PM
Holmesuser01's Avatar
Holmesuser01
Sounds like your voltage regulator is possibly bad. How old is your battery?
If your battery is charged, the alternator output should drop to near 13.0, or less.
Is your battery getiing warm?
Old Oct 17, 2005 | 05:32 AM
Bob Ayers's Avatar
Bob Ayers
14.26V is probably ok. The voltage will not drop back to 13V when the battery is charged, the voltage will remain constant, and the current will
drop.
Old Oct 17, 2005 | 05:40 AM
alchymist's Avatar
alchymist
"Mifflin Clay"
If the battery is being overcharged it will boil off the electrolyte - being low on water is a good indication of overcharging. Might want to put one of the induction ammeters over the alternator to battery wire. It should show a high initial charge rate right after starting the motor, then slowly start to taper off.
If it doesn't taper off, then it's over charging. Note that even with a full charged battery, there will be some current, due to system load.
Old Oct 17, 2005 | 04:16 PM
Franklin2's Avatar
Franklin2
14.26 is fine. I see no problem. Do you see something that made you ask the question if it was overcharging?
Old Oct 19, 2005 | 05:44 PM
1975Ford's Avatar
1975Ford
14.26 volts is in the safe range of charging, I also agree, it a good charge.
fordbroncodave
17
May 7, 2013 01:16 PM
joe f350
23
Jul 5, 2010 04:56 PM
welder1
Feb 24, 2010 04:30 PM
rdmytro
Apr 9, 2008 05:20 PM
ReAX
Electrical Systems/Wiring
19
Oct 3, 2006 06:47 PM
