Sponsored by: Kumho
ABS light
Old Oct 15, 2005 | 08:30 PM
4Wheelz's Avatar
4Wheelz
Question ABS light
Hi gang, Is the abs light supposed to always be illuminated? Mine is always on? Also, sometimes i feel a little sponginess in the brake pedal?
2000F350Super duty 7.3 psd
Old Oct 26, 2005 | 12:02 PM
1975Ford's Avatar
1975Ford
No the ABS light sould not alway be on. Check the brake pads and brake shoes, they might be worn. Check the brake fluid also.
Old Oct 26, 2005 | 06:03 PM
4Wheelz's Avatar
4Wheelz
Thanks '75 Ford
Old Oct 27, 2005 | 11:13 PM
someday's Avatar
someday
i am not sure if an obd scanner can pull brake codes but its worth a shot and if its not something obvious then somehow pull the code and it will tell whats wrong
Old Oct 31, 2005 | 10:30 AM
Raker1's Avatar
Raker1
Sponginess in the brakes would lead me to check the brake pads and shoes.
Old Oct 31, 2005 | 01:27 PM
zemus420's Avatar
zemus420
Do a quick check of the ABS fuse make sure its not burned out.
Old Nov 8, 2005 | 10:32 PM
scar98's Avatar
scar98
abs light
Speed sensor in your rear differential could be bad.Thats what caused my abs light to come on my 1999 Xlt.$25 buck part and easy to change
bubba_3711
Apr 22, 2017 10:38 PM
redman84
Oct 20, 2011 03:40 PM
scottek
16
Jan 23, 2009 06:30 AM
mrshorty
Nov 2, 2002 04:15 PM
