91 ABS lights ALWAYS on.
Old Aug 30, 2002 | 10:09 AM
mrshorty's Avatar
mrshorty
Old Nov 2, 2002 | 09:39 AM
grey169's Avatar
grey169
I have a 91 5spd. Ever since I have owned the vehicle (about 4 years now) the ABS light has stayed on. I have done a little research on the system and found that basically there are three componenets to this system. The sensor in the diff case, the computer, and the actuator. I have replaced the sensor in the diff case and no luck. The light is off when I first start the truck. It comes on when I release the brake pedal. It hasn't given me any trouble but I thought that it was high time to fix it. I would just start replacing parts but the computer and sensor are both at $200 a piece. Someone told me that there was a way to run a test on the ABS computer to verify on what is wrong. Does anyone here have a good ideas on how to start to troubleshoot this?
Thanks
Old Nov 2, 2002 | 04:15 PM
marragtop's Avatar
marragtop
This is probably a dumb question, but have you tried disconnecting the battery for about 10 minutes?? Sometimes a 'false' code will be sent to a warning light, and it will stay on until reset. Disconnecting the battery will reset it. If it comes back on, then you need to continue to troubleshoot it.
Mike
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
