remote starter short crank
Old Oct 12, 2005 | 09:48 PM
milmo1's Avatar
milmo1
I have a 99 explorer that has a dealer installed remote starter. We were
led to belive it was a ford remote starter system when we bought
it, but of course that was not true. It is a code alarm system.
It has lock and unlock with remote start and panic. The problem I
have is that when you push the button to start, it cranks real short
time and does not start.
Anybody have any insight?
I would have to return to that dealership to have it repaired by them,
and we have not had a wonderful relationship with the service
dept.
Thanks-
Milmo1
Old Oct 13, 2005 | 12:29 AM
Franklin2's Avatar
Franklin2
What model number is it? Here's their website, and they have manuals.
http://webappshttp.voxdmz.audiovox.c...vlet/index.jsp
Old Oct 13, 2005 | 09:15 AM
goofy173's Avatar
goofy173
It doesn't try to start again with a longer crank? I have a Bulldog and in the winter the first time won't start the 89 van but the second, and longer crank will.
Old Oct 22, 2005 | 10:46 PM
milmo1's Avatar
milmo1
No, it just short cranks and stops. Then I have to hit the button again so i can start it with a key.
I hope i can fix it, the wife is real upset...
Old Oct 23, 2005 | 05:19 PM
HomerWinzlow's Avatar
HomerWinzlow
Fords' original dealer installed Remote Start system was a Code system. It could be defective relay, defective module, wiring issue, or a sense wire connection IE tach signal loss. I would first look at the brake lamp circuit. If you have a bad brake lamp switch or wiring to it, it could give a false brake input from the simple vibration of the vehicle during crank mode. Of course if it gets a brake input signal it will shut down the remote start system.
tim051
Aug 7, 2013 05:38 PM
cef2lion
Jun 5, 2006 09:27 AM
milmo1
Oct 17, 2005 11:19 PM
milmo1
Mar 8, 2005 04:51 PM
