explorer suspension creak
Old Mar 6, 2005 | 09:47 PM
milmo1's Avatar
milmo1
I have a 99 explorer 4 dr 4.0 sohc. Just yesterday, the front end began to make a hideous squeak/creak noise while driving/turning. I have heard this many times from other explorers. I was just waiting my turn for this noise. Seems like this may be a common failure.
Has anybody seen something similar?
Any advice where to start?
Thanks
Old Mar 8, 2005 | 11:38 AM
95 explorer joe's Avatar
95 explorer joe
I Have A 95 With 196,000 On It And Just Had The Trans Replaced, When I Got It Back From The Shop It Had Started With The Squeaking And Creaking. I Have Sprayed Every Thing Under The Front End With Several Cans Of Liquid Wrench And I Still Have The Same Noise. I'm Going To Replace The Front Shocks Next. Good Luck And I'll Let You Know If I Find Out What It Is.
Old Mar 8, 2005 | 12:27 PM
Monty06's Avatar
Monty06
body mounts come to mind squeaks whikle you drive and when you turn.
common problem
Old Mar 8, 2005 | 01:58 PM
M.Stephens's Avatar
M.Stephens
Yes, alot of FORDS have this. I had it on my 96 Windstar and I hear it on a 2001 Navigator.
I fixed it temporarily on my WInstar, its the pin that links the A frame to the front wheel assembly. Lossen it up, lube and then tighten it supertight and it'll go away for 5-6 months.
Old Mar 8, 2005 | 04:51 PM
yield2s's Avatar
yield2s
inspect the rubber tie-rod end boots, if they're cracked open then it's your tie-rods.
mtnxtreme800
2009 - 2014 F150
18
Aug 14, 2015 06:55 AM
KJR05
Mar 1, 2014 10:36 AM
bigshotsho93
Jul 3, 2010 07:39 PM
mroberts
17
Oct 18, 2006 02:28 PM
DeGideo
1978 - 1996 Big Bronco
Nov 18, 2002 04:53 PM
