Downpipe install?
Old Oct 11, 2005 | 10:17 PM
filipows's Avatar
filipows
Question Downpipe install?
I want to put a 3" downpipe on my 95 F250. Is this a difficult task? Can it be done reasonably at home?
Have any readers did their own install. I have also heard that some instalations require the fire wall to be modified? Has this been the case?
Thanks
Dennis
Old Oct 11, 2005 | 10:53 PM
mjwhip2's Avatar
mjwhip2
I had to tweak my firewall a bit. Wasn't too terrible. The hardest part for me by far was removing the old downpipe. Took 3 or 4 blades for the sawzall.
Do a search here and you will find many, many tips for getting it done.
Old Oct 11, 2005 | 11:11 PM
ltfox's Avatar
ltfox
http://www.drivetrain.com/downpipeinstinstr.html
Best instructions's I've ever found......
Only thing I don't think is needed is the heat wrap.
Old Oct 12, 2005 | 08:07 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Thanks
Dennis
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Oct 12, 2005 | 10:17 AM
1997F-350's Avatar
1997F-350
it's very easy as long as you got something to cut with. preferably sawzall. they are cheap at harbor freight. some handtools and something to bend the firewall with pipe, 2x4, scissor jack or porta power.
Old Oct 12, 2005 | 05:24 PM
Max1775's Avatar
Max1775
If your cab bushings have never been changed, they're probably worn out. You have to jack up one side then the other to change the bushings, and it makes it real easy to get the downpipe out while the truck is jacked up on the passenger side. It will also help with any clearance issues once the new downpipe is installed. A new set of polyurethane bushings from Energy only cost me about $65 and it eliminated some of the squeaks and pops I had as well. Hope it helps.
Max
Old Oct 12, 2005 | 07:15 PM
filipows's Avatar
filipows
Thanks to every one for all the advice and share of experience. I will probablay need to wait a little to do the swap, but it seems like something I can tackle. Have there been brands of pipes that seem to fit better?
Thanks again
Dennis
Old Oct 12, 2005 | 07:22 PM
1997F-350's Avatar
1997F-350
Thanks again
Dennis
hypermax downpipes are pretty good.
Old Oct 12, 2005 | 11:30 PM
mjwhip2's Avatar
mjwhip2
I went with Dale Isley's (Tymar Performance) downpipe. Starts at 3" expands to 3.5" after the seam, then to 4" to mate up with a 4" exhaust the rest of the way back. Probably the best downpipe made for the money (~$130).
Old Oct 13, 2005 | 06:42 AM
1997F-350's Avatar
1997F-350
exactly the man to go too. hypermax dp
bduemig
Jul 11, 2014 12:58 AM
Diesel_Brad
Jul 10, 2010 11:52 AM
jdv19
Mar 23, 2010 12:14 AM
njellison
May 19, 2009 03:50 PM
tprice73644
Oct 9, 2004 03:20 AM
