Water pump and reverse flow question
Old Oct 20, 2005 | 11:19 PM
  #31
LxMan1's Avatar
LxMan1
The way you have your belt is correct for the reverse flow. It isn't slipping as the rpms go up on the waterpump is it? Regardless, you should have flow with the thermostat open if it is turning. Does it have a truck radiator in it that is downflow or has someone installed a crossflow unit?
Also check to make sure that it isn't sucking the bottom hose together restricting flow.
EricJ, You are correct on the timing chain covers, Must be the pain meds from my broken finger that I just had pinned causing brain failure
Old Oct 21, 2005 | 09:00 PM
  #32
735.0Short's Avatar
735.0Short
looks like shes workin finei discovered something weird tho i got those gauges i was telling you guys about as i went to nstalled em i noticed it had a new type of water sensor and guess what? it works it moves up as the tempreture goes who ever im not to sure if to count on it or not it hooked up to the dash the original water gauge its weird what do you guys think?
Old Oct 21, 2005 | 10:04 PM
  #33
Bad2ThBone78's Avatar
Bad2ThBone78
yup seems to be so
Old Oct 22, 2005 | 06:08 AM
  #34
User 71024's Avatar
User 71024
I think your taking LX's pain meds , can you translate that?
and LX, where was your finger when it broke?
Old Oct 22, 2005 | 08:27 AM
  #35
735.0Short's Avatar
735.0Short
hah i tend to mispell when im typing fast but i thought it was weird that the old water gauge on the dash is working with the new sensor in the engine. put it this way its the sensor from the 5.0 and its working on a 32 Y/o Gauge
Old Oct 22, 2005 | 10:18 AM
  #36
User 71024's Avatar
User 71024
that doesn't surprise me, ford tends to keep things the same for years. Even the wire colors are the same for 50 years on most common parts.
the water and oil pressure sender wires have been red/wt and wt/red on every ford I have owned from the 56 tbird up
Old Oct 22, 2005 | 08:43 PM
  #37
LxMan1's Avatar
LxMan1
Actually, it was at work where it belonged when I smashed it 2 months ago. It got caught between a heavy cover and a belt pulley. I didn't even know it was broken until a couple of weeks ago when I had it x-rayed because I thought it might have had some calcium build up because it was still pressure sensitive and had a lump on top. Turns out that the lump is actually a bone chip so they went in and reset the chip and pinned it. Man is it sore and feels like it is as big around as my leg right now.
So, is the water circulating like it should now? A large air pocket perhaps?
Old Oct 23, 2005 | 01:55 AM
  #38
735.0Short's Avatar
735.0Short
seems to be working out fine now i wont see it for i dont know how long its off at the electrician now getting the lights fixed and turn signals so shell be gone for a while hopefully doesnt turn out to be to expensive
Old Oct 23, 2005 | 05:37 AM
  #39
Torque1st's Avatar
Torque1st
Posting Legend
From the "drawing" it does not look as if you have enough wrap on the water pump pulley to drive the pump OR fan. The alternator wrap looks marginal also.
Old Oct 23, 2005 | 12:07 PM
  #40
735.0Short's Avatar
735.0Short
its workin perfect torque the belt is nice and tight how much more must it be on the pump? i was also thinking it may not be enough but seems to be runnin fine
Old Oct 23, 2005 | 12:09 PM
  #41
User 71024's Avatar
User 71024
I wouldn't be concerned unless you get belt squeel, those serps have pretty good traction, I've seen factory setups that I didn't think had enough contact but they seem to work fine.
Hennington400
16
Sep 20, 2016 07:10 PM
xplodn
Modular V10 (6.8l)
42
Aug 10, 2015 03:18 PM
Customcab
13
Aug 21, 2009 01:21 AM
j tate
22
Dec 31, 2006 07:04 PM
5x5F150
Jan 5, 2003 11:51 AM
