Radiator support cross reference??
Old Oct 26, 2008 | 02:14 PM
Customcab's Avatar
Customcab
Can a 65 F600 I beleive or so, (don't know exactly F series) it has a 240 engine & the instep like my 64 F100 model. Are those radiator support's identical or interchangeable? Found one looks in better condition from the upper portion then which I currently have in my 64 model.
Thanks
Mitch
Old Nov 17, 2008 | 07:10 AM
aysw6670's Avatar
aysw6670
61-66 radiator supports are the same for pickups, but I am not sure if the larger trucks are the same as the pickups.
Old Nov 17, 2008 | 09:03 AM
Customcab's Avatar
Customcab
Thanks for the reply, I plan on going down & check it alittle closer & spray some BP Blaster on all the bolts etc, the top looks the same and the only thing I really question is where the bolt's bolt to the frame rail down beside the radaitor, don't know if its a wider frame at the front portion, looks to be same; will also measure that part as well; thanks again for helping me think this through..
Mitch
Old Nov 17, 2008 | 10:20 AM
daveengelson's Avatar
daveengelson
Can't speak to the 600 series, have a 65 F100 and found radiator support is only interchangeable with the 66 F100 4X4. During, and still in infancy stage, of salvage shopping, few yrs back replaced 65 rad support with a 66 and got home to find inner fenders would not bolt up and ended up going back for the 66 inner fenders. Suggest run search on topic and narrow field to 61-66 forum. Here's a recent thread on subject, not sure if info is any help for your application.
https://www.ford-trucks.com/forums/7...-supplier.html
Old Nov 17, 2008 | 10:50 AM
camperspecial65's Avatar
camperspecial65
61-4 F100-250 2 and 4 wd, 61-6 F350, are the same as 65-6 F350-F600, 65-6 F250 4WD and 65 F100 4WD are all the same...C2TZ16138-G
The 65-6 F100 and 250 are each to their own as far as interchangability...the 66 F100 is the same as the 65 F100 and F250 2WD...
C6TZ16138-C
The 66 F100 and F250 2wd is C6TZ16138-B
So...to answer your question...will the F600 fit your 64 ...be sure of the big trucks VIN series though as B and F 700 and 750 are different then the trucks up to F600 series...
- cs65
Old Nov 17, 2008 | 06:28 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1961/66 Radiator Supports / Core Supports
That's total nonsense...where the did you get that info from?
There are THREE different radiator supports for 1961/66 F100/350 Pickups.
C2TZ16138G = 1961/64 F100/250 2WD/4WD / 1961/66 F350/600 / 1965 F100/250 4WD / 1966 F250 4WD.
C6TZ16138B = 1966 F100/250 2WD
C6TZ16138C = 1965 F100/250 2WD / 1966 F100 4WD.
This is prolly the 50th time I've typed this info here on FTE in two years.
Old Nov 17, 2008 | 07:30 PM
gangstakr's Avatar
gangstakr
And we thank you, N.D.
Old Nov 17, 2008 | 10:20 PM
Customcab's Avatar
Customcab
Thanks cs65 & Number Dummy; I'll copy those parts numbers and reference those type vehicle's again thanks for your support.
How do I determine if the truck in the salavage yard matches one of these radaitor support. I'll try & get the vin data and post it soon and hopefully you guys can tell if it will work. If not I guess I have to save up so dough and pm gangster...
Mitch
Old Nov 18, 2008 | 01:17 PM
camperspecial65
Im not sure about big trucks, but the pickups have the VIN stamped on the top of the passenger side frame rail about a foot or so in front of the engine crossmember...an F600 would start with F60 in its VIN...
- cs65
Old Nov 18, 2008 | 07:05 PM
Customcab's Avatar
Customcab
Thanks for the reminder CS65, I just don't see too many large trucks in my area.
Mitch
Old Aug 17, 2009 | 03:21 AM
johncanida's Avatar
johncanida
i need a core support for my 65 f100 and some places are making them new, which one do i need!
Old Aug 17, 2009 | 04:27 AM
NumberDummy
Welcome to FTE
AFAIK, this is the only radiator support that has been reproduced.
Several members here say it can be used on 1965/66 F100/250 2WD's, but it has to be modified.
Old Aug 17, 2009 | 08:22 AM
gangstakr's Avatar
gangstakr
I have three of these:
All in great condition.
Old Aug 21, 2009 | 01:21 AM
johncanida's Avatar
johncanida
Any of them will fit with out a problem? Whats the best one for my truck and how much! If you want to sell one?
joegeds
Sep 30, 2015 06:24 PM
Shadowrider123
Jun 17, 2015 01:18 PM
Shadowrider123
Jul 5, 2014 04:14 PM
barryf
Oct 11, 2011 07:27 PM
sgettin
Dec 5, 2009 03:08 PM
