Did I screw up?
Old Jan 2, 2003 | 10:52 AM
5x5F150's Avatar
5x5F150
Did I screw up?
Back in the summer I noticed my 96 302 F150 was over-heating. Not much but in the 80k I've owned it (now at 160k), it never deviated-dead center off the NORMAL. So I decided that it was time to give the old girl a rad flush and new thermostat. I know my way around the shop, and don't usually make mistakes. When I finished my engine ran in the beginning of NORMAL, which then made me think that was where it was supposed to sit. Now I have changed the thermo. again as it never warmed up(its about 0 deg Farenhietaround here) any ideas as to what may have happened here? Thermo in backwards this time? Last thermo was faulty.
5x5F150
Old Jan 2, 2003 | 11:34 AM
gasman6674's Avatar
gasman6674
Did I screw up?
[updated:LAST EDITED ON 02-Jan-03 AT 12:34 PM (EST)]I have owned two ford 302's. One in a 79 F100 and my current 92 F150
neither has had a "good" heater. I had to block the radiator on the 79 to defrost the windsheild. I have put in 3 Tstat's in the 92,a new gauge sender and a water pump and it still reads about "O" in normal. I had a 95 F150 with a 351 and it had a great heater so I dont think its the heater core.
My .02
Gasman
Do you have Gas?
Propane Execeptional Energy
Old Jan 2, 2003 | 12:38 PM
pcmenten's Avatar
pcmenten
Did I screw up?
What temp thermostat did you install. I made the mistake of putting a 180 tstat in my 86 Mustang. That bugger runs rather cool, too cool. If the cooling system is in good repair, your best bet is a 195 thermostat.
Old Jan 5, 2003 | 11:48 AM
Quantrex's Avatar
Quantrex
Did I screw up?
I like to install a 180 degree thermostat and straight water in the late spring and then switch to a 210 degree thermostat and an antifreeze mix in the fall for my 289. It's not that much extra work and helps keep the radiator and heater core clear of buildup.
Old Jan 5, 2003 | 11:51 AM
Quantrex's Avatar
Quantrex
Did I screw up?
Hennington400
16
Sep 20, 2016 07:10 PM
Willy Ray White
Mar 25, 2016 04:36 PM
F-250 restorer
Dec 9, 2015 04:25 PM
JML31
Oct 3, 2010 06:09 PM
735.0Short
40
Oct 23, 2005 12:09 PM
