Sponsored by: Real Truck
View Poll Results: What lift kit manufacturer do you use?
CST
0.34%
Donahoe Racing
130
22.18%
Fabtech
73
12.46%
Pro Comp
110
18.77%
Rubicon Express
1.02%
Skyjacker
77
13.14%
Superlift
72
12.29%
Other
116
19.80%
Voters: 586. You may not vote on this poll
Lift Kits
Old Apr 25, 2006 | 12:12 PM
  #91
JJ 4WD's Avatar
JJ 4WD
My Lift Info
I used a Rancho 4" Suspension lift on my 2005 F-250 SD Crew Cab PSD. I used their RS9000 shocks and currently have set to 4 in front and 3 in rear. I put on BFG AT's 315/70R17's with American Racing Mojave polished wheels (17x8, 0 offset, 4.5" backspace). I had it installed for me. My gear ratio is 3.73 and I haven't changed it. No real noticable difference in acceleration. Fuel mileage went down about 1.5 MPG on average. No tire rubbing whatsoever. Tires do stick outside of wheel well 1-1.5". May put on fender flares to eliminate spray onto side of truck. Love the ride - better than stock. And really love the look - especially the red Rancho components. The height is perfect for what I use the truck for (occasional off roading and hunting) and the tires fill the wheel well nicely (not too big or small looking).
Old Apr 26, 2006 | 10:46 PM
  #92
evildesel's Avatar
evildesel
lift kit
1. Procomp 2 inch level kit front blocks
2. rear stock with procomp trac bars
3.procomp shocks
4. skyjacker dual steering stabilzers
5. pro comp tires extreme terrain 325/65/18
6 weld racing dune 8 18 x10
7. installed by Turner Automotive/ Onatrio,Canada
8.www.tadiesel.com
9. rides like stock, handles awesome
2006 f350 4x4 srw ccsb psd 6.0
Old Apr 27, 2006 | 10:50 PM
  #93
HuntsDucks70's Avatar
HuntsDucks70
Hello all, my first post. I've had the 3.5" Fabtech hanger kit for about 4 years but just ordered a 6" Superlift w/rear blocks, can't wait to install it, hope I made the right decision, researching the lift was consuming me and my wife could not take it any more, my decision was largely based on the posts of you good people, thanks and i'll post some pics once the lift is complete
Old May 4, 2006 | 08:24 PM
  #94
kimminau2's Avatar
kimminau2
3.procomp shocks
8.www.tadiesel.com
How do you like the Pro Comp extreme all terrain's. That is what I am going to. Are they real noisy? How is the highway ride?
Old May 6, 2006 | 04:46 PM
  #95
kaipo's Avatar
kaipo
Smile 2005 scsd F-350
6" fabtech with a 2 1/2" leveling kit added on total 8 1/2" front stacked blocks in the rear fabtech basic kit.
18x10 Mickey Thompson Classic Lock wheels 325/65/18 (33x13.50x18) MickeyThompson ATZ's.
Self installed!
Didn't have to trim fenders when even when I had the 6" Lift
Old May 7, 2006 | 09:53 AM
  #96
Bill's2000X's Avatar
Bill's2000X
I'm currently trying to install a 4" skyjacker suspension lift with skyjacker shocks. I have a 2000 Excursion. I'm not sure what gears I have, but I have a RC27 code on my door. I assume it is for 3.73, but can someone help decifer this code for me? I also have 18 inch Mazzi wheels and want to put new tires on. I don't know what size my gears can support, but I'd like a 35 or 37 inch tire. I'd appreciate any help with the decoding and tire sizing. I've seen the tire size formula, but don't know what gears I currently have.
Old May 7, 2006 | 10:12 AM
  #97
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
it is ona tag under a bolt holding the rear differential cover on. it should read 3.73L or L3.73 if it's limited grip.
Old May 13, 2006 | 01:28 PM
  #98
rpdwelding's Avatar
rpdwelding
lift kits
6" pro comp
Rear add a leaf and 1.5" block
pro comp shocks
Stock steering stabilizer
Pro Comp extreme all terrains 37"x13.50"x18"
Ford factory 18"
installed by RPD Welding and Fabricating
Rides same as stock. pro comp makes a great kit.
2006 F 350 lariat 4x4 crew cab long bed 6.0 powerstroke
Old May 13, 2006 | 06:37 PM
  #99
kaipo's Avatar
kaipo
Hey Bill's2000X
35's will do plus on a 4" lift you'll run into rubbing issues with 37's. The 35's would look real nice on your rig.3.73 gears will do just fine if your tires are not that wide. 13.50 max after that, bigger gears.
Aloha,
Aaron
Old May 14, 2006 | 03:03 PM
  #100
PowerstrokeJunkie
Originally Posted by kaipo
Hey Bill's2000X
Aloha,
Aaron
what does the width of the tire have to do with the gearing? the overall diameter is what matters with gearing. i am assuming that you are thinking the increased rolling resistance of the wider tires calls for steeper gears?
Old May 14, 2006 | 04:40 PM
  #101
kimminau2's Avatar
kimminau2
I was thinking the same thing.
Old May 14, 2006 | 05:35 PM
  #102
kaipo's Avatar
kaipo
Smile
Thanks. Yeah steeper gears. My bad steeper and bigger.
Aloha,
Kaipo
Old May 14, 2006 | 06:26 PM
  #103
BFR250SD's Avatar
BFR250SD
Not trying to be the bad guy, but let's keep this centered toward the lift kits. We have lots of threads on gears and such.
Thanks guys!
BFR
Old May 14, 2006 | 07:25 PM
  #104
PowerstrokeJunkie
if that's the case, on friday i just bought a Donahoe Racing 4.5" spring hanger kit. it should be here next monday (22nd) or so and i'll inform you all on how i like it!
Old May 14, 2006 | 08:21 PM
  #105
kimminau2's Avatar
kimminau2
I just had my 3" DR lift and Pro Comp tires installed. I love it. It rides better than stock and handles better than stock
