Sponsored by: Real Truck
View Poll Results: What lift kit manufacturer do you use?
CST
0.34%
Donahoe Racing
130
22.18%
Fabtech
73
12.46%
Pro Comp
110
18.77%
Rubicon Express
1.02%
Skyjacker
77
13.14%
Superlift
72
12.29%
Other
116
19.80%
Voters: 586. You may not vote on this poll
Lift Kits
Old Jul 11, 2006 | 04:06 PM
  #136
electrk's Avatar
electrk
DR 2" mini spring pack, fab tech adj trac bar, skyjacker extended sway bar end links, rsx shocks and steering stabilizer.
I went with 16x8 pro comp wheels with 4.5 back spacing to keep the 35's inside the wheel wells as much as possible.
The truck rides better than stock as the shocks are an upgrade. The slightly wider stance also feels more stable.
The adj trac bar made the install easier and the axle is centered better now than stock. I also plan on lifting the truck again after my warrantee runs out in a year or so, and the adj trac bar will be needed more so then.
The whole package including tires and wheels installed cost about $2800
I'm very pleased with the results so far.
There are pictures in my gallery.
Old Jul 12, 2006 | 06:11 PM
  #137
Cobra97Vert's Avatar
Cobra97Vert
I have the fabtech with an 8" lift and dual shocks. Tires are 17x9 with 37's. The setup cost me $6400 installed.
Old Jul 15, 2006 | 12:32 PM
  #138
HUGHHOLLAND's Avatar
HUGHHOLLAND
1 - Type kit and how big
2 - Rear springs, blocks or add-a-leafs
3 - What shocks
4 - What tires and size
5 - [font=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif][font=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]Gear [/font][font=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]ratio[/font][/font] and what would you go to
6 - Self install or shop
6a - If self install, how difficult and what problems
7 - What is YOUR impression of the kit overall
8 - If you could have, what would you change
9 - If you wouldn't mind, how much you paid for the LIFT
2006 F-250 PSD CREW CAB FX4
1- FABTECH RADIUS ARM- 8 INCH
2- CUSTOM MADE LEAF SPRINGS FROM SHOP IN TOWN
3- BILSTEIN 5100
4- PROCOMP XTREME AT'S- 38.5/14.50/18
5- FACTORY GEARS- 3.73 FOR NOW
6- SELF INSTALL
7- RIDES BETTER THAN STOCK
8- NOTHING
9- PAID 3900 FOR LIFT, WHEELS, AND TIRES REAR SPRINGS AND SHOCKS SO SEPARATELY
Old Jul 15, 2006 | 01:41 PM
  #139
Cobra97Vert
couldnt edit, pics fixed
Old Jul 15, 2006 | 02:49 PM
  #140
kaipo's Avatar
kaipo
Sweet rig! What kind of tires are those? Looks pretty wicked.
Last edited by Beast12; Jul 15, 2006 at 04:35 PM. Reason: removed quote from previous post. waste of bandwidth
Old Jul 15, 2006 | 10:19 PM
  #141
rudedogii's Avatar
rudedogii
Pro Comp to Superlft
2000 Superduty Crew Cab V-10
37x13.50x17 Goodyear Mtrs on Centerline Coolers
I first started with a 6.5 Procomp lift, used for $700.00. Installed myself good height but stiff as ^%$$@#! The Procomp leafs are only five or six leafs and rated at 490lbs/inch front, and 375lbs/inch rear.
Also running Procomp ES9000 duals front and single rear.
I was looking at the Skyjacker Softride lift but I got a better price on a Superlift kit.
The 8 inch Skyjacker kit recommends a heaver sway bar? Is this because of softer springs?
Any way the Superlift leafs are made in India for the rear and Canada in front. Tens leafs per pack. The cost $1400.00 for a complete kit all spring.
Was the ride any better? Very little differance.
I plan on trying the Skyjacker springs next and maybe some Bilsteins 5150s.
The question should be what do you use your truck for?
A Superduty will never be a Prerunner, but a Superduty can haul and tow!
Old Jul 15, 2006 | 10:31 PM
  #142
rudedogii's Avatar
rudedogii
I youre looking for smooth ride buy a Chevy, or GMC, they ride smooth but are very week in the front end.
Old Jul 16, 2006 | 10:37 AM
  #143
Ronin007's Avatar
Ronin007
LOL!!! That is a funny statement considering a lot of people here rave about the ride of the Donahoe kits. And where were the kits developed and what does Donahoe Racing do?? Desert racing a Super Duty last I knew!!!
Old Jul 16, 2006 | 04:42 PM
  #144
kimminau2's Avatar
kimminau2
I love the ride of my DR, definitely better than stock. But to each his own.
Old Jul 16, 2006 | 09:14 PM
  #145
rudedogii's Avatar
rudedogii
DHR Lifts
There is always a trade off, do you want maximum hauling and towing capacity, or do you want to go fast over woops.
I bought my F250 crew cab 4x4 to tow me, my family, freinds, and all the toys. Isn't that what a Superdutys for?
I got a Ford Bronco to go real off roading, but I know the Superduty can always haul the Bronco out and back!
Old Jul 16, 2006 | 09:56 PM
  #146
Ronin007's Avatar
Ronin007
A Super Duty is for whatever you want it to be. Some tow, some plow, some off road, some show, and some just get the groceries with theirs. The bottomline is they are a great truck to build into whatever you want it to be. I think Donahoe Racing proved that they can be a great desert truck and 4-Wheel and Off-Road proved that you could build one to wheel with a bunch of Jeeps and buggies on some tight trails. If all you want to do is tow with yours that is fine, but they can do so much more than that if you want.
Old Jul 21, 2006 | 04:46 PM
  #147
Tophfire's Avatar
Tophfire
EnviroCon....
I just joined FTE.
I noticed you did the Donahoe 4.5" on your truck. I did the same with mine. I've got 35's as well. My front drivers side tire rubs very little and i'm worried about the tire grabbing the ABS lines that are near the frame. Any suggestions? Thanks..
Old Jul 21, 2006 | 05:09 PM
  #148
EnviroCon's Avatar
EnviroCon
Originally Posted by Tophfire
EnviroCon....
I just joined FTE.
PM'd you back.
Old Aug 9, 2006 | 02:13 PM
  #149
Pickupmanx2's Avatar
Pickupmanx2
I have an 02 X 4x Limited 7.3, I initially went with a BDS kit, cheapo crap, IMHO!
I then went with Fab-Tech, 5 1/2" kit, Bilstein shocks, dual in front, went back to block in rear for ride purposes. I have 315/75/16s on Mickey Thompsons Classic IIs. Rides wonderful, not AS cushy as stock. I have straight-piped it, K&N Air, Hypertech 3 stage. I regularly tow our 27' Ragen Toy-hauler, about 10,500 loaded, and get 9-12 towing it. I wouldn't go any higher for towing, works great for us, it has about 80k miles, just went to TX, no trailer, averaged 19.5 the WHOLE 3700 miles, had a few runs of 80mph+ for a while, like to drink the fuel once you go past 75.
Old Aug 11, 2006 | 10:02 PM
  #150
Deablo's Avatar
Deablo
Talking
Hey, how is everyone, I'm kinda partail to One Up Offroad syspension systems.
