Oil leak, help
Old Oct 10, 2005 | 11:56 AM
oem78's Avatar
oem78
Oil leak, help
I have 1979 300 6cy that is leaking oil on the bottom to the oil pan under the timming cover. I have replaced the oil pan gasket and put a sleeve on the dampner or harmonic balancer and it leaks worse than before, I thinking of putting on new timming gaskets. Where can the oil be comming from, I dont' believe its the oil pan gasket, even though thats were the oil is seen.
Old Oct 11, 2005 | 09:33 PM
optikal illushun's Avatar
optikal illushun
the bottom of the timing cover also uses the erl pan gasket to seal.
did u use any RTV on the bottom to help seal it up? and is it in evenly?
bizzelj
Apr 12, 2015 06:20 AM
Phil Woolfson
May 20, 2014 07:36 PM
moneypit79
Jul 8, 2013 08:27 PM
Tim J
47
Aug 3, 2008 10:45 AM
WALFORD'S 56
Oct 3, 2007 05:56 PM
