Oil pan leak
Here is some of the fun involved in a bed plate reseal job.
Just watch the rest of his 6.0 videos on the full job.
Like you have already been told do the simple things first.
If that stops the leak then you are saved. 1 Qt lower on the
oil fill can also stop the drip and won't hurt anything.
Sean
Sean
Well 2 reasons that you have to pull the engine to do a
reseal on the bed plate. Parts like bearings sometimes stick
and then fall into the dirt pile on the floor. (don't know how they find it but they do)
2nd reason you have to pull the engine rear cover and when you
reinstall it you also have to put a new main seal in. That is less of
a pain in the *** if the engine is out or you have to pull the trans.
Not a job for the faint of heart that is for sure.
Sean
Sean
