1997 Expedition rear climate control not functioning properly
I have a 1997 Expedition Eddie Bauer and for some reason the rear climate controls dont respond correctly when I change the temp or air flow direction. The blower motor speed works w/o issues but when I try to select the air to come out of the ceiling it will do its own thing and usually comes out on the floor. The same goes for when I want heat it will send cold air or it might send luke warm air. Any idea what might cause this and how to fix it? A year ago when I asked this question someone said it could be a vacumm leak but I cant seem to locate where the leak would be. FYI.... the climate controls on the dash for the front vents work with no problems.
