replacing a coil
Old Oct 10, 2005 | 08:36 AM
dr worm's Avatar
dr worm
Question replacing a coil
i have a bad coil on plug #7 on a 02 expedition is it hard to replace?
Old Oct 10, 2005 | 10:07 AM
Luzer27's Avatar
Luzer27
That is a subjective question. I personally believe that if you can change your own oil you could do the #7 coil pack. It will be the 3rd cylinder back on the drivers side and I believe you will need a 7mm socket and 1/4 ratchet setup. This side of the motor is very open and accessable. The coil packs are directly over the plugs and you will NOT need to remove the fuel rails as a lot of do it yourself books suggest. Also the fuel injector harness may interfere but the will rotate out of the way with little effort. Also the coil pack should be in the 40-55 dollar range and if the boot is torn or cracked it is around 7 bucks.
Dave
Dave
