band adjustment
Old Oct 9, 2005 | 10:58 PM
kelvis's Avatar
kelvis
band adjustment
Gidday,
Is anybody able to give me instructions on how to adjust 1st gear bands to (hopefully) stop slipping in 1st? Its a C4 in a 71 F100 Ambo.
Thanks
Kel
Old Oct 10, 2005 | 09:46 AM
Mike G's Avatar
Mike G
I would check with the gang in the Trans forum, but I did the adjust on my C6 and it's quite simple. There is(should be) a threaded rod with a screw driver slot on the side of the trans. Lossen the hold-down bolt and twist in the rod. I would go 1/2 turn at a time and see what you get.
--Mike
Old Oct 10, 2005 | 12:01 PM
BobbyFord's Avatar
BobbyFord
A C6 has only one band, for 2nd gear. To adjust it, loosen and back off the lockdown nut on the square-headed bolt on the left side of the trans, tighten the square-headed bolt to 10 ft. lbs, back out 1 1/2 turns and lock the nut back down.
Follow the same procedure to adjust the front band on a C4.
For the rear band on the C4 (low/reverse), follow the same procedure as the front band, except back out the square-headed bolt 3 turns.
Old Oct 10, 2005 | 08:02 PM
kelvis's Avatar
kelvis
C4 slipping
Gidday instig8r63,
Thanks for your response.
There are 2 adjusting bolts, one on each side of the tranny. Do you know which one is the first gear adjuster?
Thanks
Kel
Old Oct 10, 2005 | 10:10 PM
BobbyFord's Avatar
BobbyFord
The adjustment toward the rear of the trans is the low/reverse band, the one toward the front is the 2nd gear band.
Hope this helps.
Good luck!
Old Oct 14, 2005 | 07:06 AM
kelvis's Avatar
kelvis
C4 slipping
Gidday instig8r,
As I havent done this befofe I just want to confirm your instructions. I wind the adjuster all the way in and torque it to 10 ft, then wind back out 3 complete turns? Is that correct?
Thanks Mate
Kel
Old Oct 14, 2005 | 07:39 AM
BobbyFord's Avatar
BobbyFord
Yes, Kel, that's correct.
Old Oct 14, 2005 | 09:08 PM
kelvis's Avatar
kelvis
C4 slipping
Thanks for your help
Regards
Kel
Old Apr 1, 2006 | 07:23 PM
snotwilim's Avatar
snotwilim
10 foot pounds on the C6 band
Would 120 inch pounds be the same as 10 foot pounds? I've got a torque wrench that doesn't go any lower than 30. However the inch pound wrench might can do it if I have my numbers right? Anyone know?
Old Apr 1, 2006 | 07:52 PM
Ford_Six's Avatar
Ford_Six
Sounds about right.
warren e
Jun 20, 2017 11:55 AM
MURDOMINO
25
Oct 25, 2016 08:33 PM
tygerrrr
Aug 30, 2009 02:50 PM
adam_harding1234
May 24, 2007 09:09 PM
78fordman
Nov 3, 2003 04:19 PM
