1978 - 1996 Big Bronco
Tailgate Splitting ??
Old Oct 7, 2005 | 05:21 PM
Salmonhead's Avatar
Salmonhead
So the top right edge of my tail gate is splitting open on the side (about 2 inches so far). How would you go about making a good repair? It appears to be metal fatigue (from tire carrier closing??). I prefer to do my own amateur body work (gives it that personal touch)!
Thanks
Old Oct 7, 2005 | 05:24 PM
bossind's Avatar
bossind
Thanks
Mine did that years ago, its from the spare tire pulling on it, I mig welded mine along the edge and filed it smooth and hit it with touch up paint. It never did it again.
Old Oct 7, 2005 | 09:50 PM
Salmonhead's Avatar
Salmonhead
Thanks Bossind! Now I have to admit that I've just started looking at welders. http://www.harborfreight.com/cpi/cta...temnumber=6098. Do you think this is a reasonable home welder for someone on a tight budget?
Old Oct 7, 2005 | 10:00 PM
BroncoBill's Avatar
BroncoBill
Salmon, this will be fine for the project in question. I was fortunate enough to go through Auto Body I & II during 1991-92 and learned a lot about automotive welding. Good luck and have fun with the welder Sir. Bill
Old Oct 8, 2005 | 12:18 AM
greystreak92's Avatar
greystreak92
You can keep this from happening to a tailgate and never have to take a welder to it at all. This is of course assuming yours hasn't begun to split. If you HAVE the exterior tire carrier on your Bronco, there is an issue with the way the carrier latches that is the principal cause of the tailgate "splitting its seams" as it were. The latch ISN'T the problem but it can be the cure. The problem is that the bumper at the bottom of the carrier is very thick and when you close the carrier it actually torques the carrier agaisnt the latch. The carrier was engineered to latch this way to keep it from rattling (a common problem with older versions of the carrier). This is great but the constant "pull" that the carrier does (even without a tire on it) against the outer skin of the gate, causes the edge to split. Check my gallery "Tire Carrier Torque Fix". I addressed the problem by shimming the latch on the gate out about 3/8" and filing about 1/4" of the rubber off of the lower rubber stop. The new tailgate shows no signs of stress and the carrier does not rattle at all... even loaded with a 33x 12.50 A/T mounted on it.
Old Oct 8, 2005 | 07:03 AM
jem270's Avatar
jem270
Mine split about 2 inches on the right a couple of years ago. I took the carrier off and stored it in the garage.
1988 EB Bronco - 302 - AOD - 3.55 Lim Slip 8.8- Manual Hubs and Transfer Case - BFG 32/11.5 AT - 209,000 miles
Old Oct 8, 2005 | 08:57 PM
Salmonhead's Avatar
Salmonhead
Thanks everybody - great information as usual! Greystreak, will it hurt to go ahead and trim the bottom stop until I get the shim material?
Old Oct 9, 2005 | 02:21 PM
greystreak92
No, it won't hurt at all. you just want to be careful not to trim too much or the carrier release handle will smack the painted surface of the gate when you close it.
Mr. Finch
Appearance & Dress-Up
Mar 13, 2005 06:57 PM
Mr. Finch
Mar 9, 2005 09:05 PM
bigskyrchry
Feb 22, 2003 06:25 AM
chewy_ocpa
Feb 2, 2003 02:57 AM
ford_nut
Jul 7, 2002 09:17 PM
