Gear selector indicator light
Old Oct 3, 2005 | 06:57 AM
jenkinsj's Avatar
jenkinsj
Is there a light on the gear selctorindicator? This would be on a 78 F150 tilt wheel column shift. If so how do you change the light bulb or which wire coming out of the steering wheel wiring harness goes to the light?
Thanks.
Jenkins
Old Oct 3, 2005 | 09:06 PM
Franklin2's Avatar
Franklin2
Is your indicator in the dash or on the column itself? I am not familiar with how the older trucks are setup.
Old Oct 4, 2005 | 07:09 AM
jenkinsj's Avatar
jenkinsj
On the column
Old Oct 4, 2005 | 04:21 PM
Franklin2's Avatar
Franklin2
I did a search and found this. It doesn't sound very easy.
https://www.ford-trucks.com/forums/s...indicator+bulb
Old Oct 5, 2005 | 06:58 AM
jenkinsj's Avatar
jenkinsj
Thanks Dave. I appreciate your help. a while back I think it was you that sent me a link for the wiring diagram for a 64 ford. I used that and an 80 ford haynes manual to hook up the wiring in a 78 tilt wheel column to the blinkers in my 64 ford and then found the brake light feeder wire. It all works pretty smooth.
Jack
gobzofzeal
1997 - 2003 F150
Feb 27, 2025 02:31 PM
Joseph Jenkins
Jul 7, 2012 07:33 AM
Jenkins6586
May 12, 2011 08:18 AM
jenkins2
1997 - 2003 F150
13
Jun 20, 2010 09:44 PM
Jenkins6586
Electrical Systems/Wiring
Aug 3, 2004 11:33 PM
