running board lights not working?
Old May 11, 2011 | 05:02 PM
Jenkins6586's Avatar
Jenkins6586
hello i just bought a 97 expedition and the running board lights are not working checked the fuses and there good. i dont know how to get at the bulbs the check them or to check for power. is there a write up some where on how to take them apart with out breaking anything?
Old May 11, 2011 | 06:53 PM
hotfalcoon's Avatar
hotfalcoon
If I remember correctly there is one plastic screw in the cover, take that out and slide the cover off. Then turn the light socket 1/4 turn to the left and pull to release it from the running board. Then pull the light bulb straight out. Installation is reverse.
Old May 11, 2011 | 07:46 PM
alloro's Avatar
alloro
You remember correctly.
Just to clarify, these steps are done underneath the running board, the lens on the top does not pop off.
Old May 12, 2011 | 07:00 AM
hodges710's Avatar
hodges710
Just to help being I had a situation with mine, I am not sure if its the main fuse(theres another light one in the fuse box inside) but there is one directly for the running board lights in the small strip of fuses along the drivers side fender labeled #4.
Old May 12, 2011 | 08:18 AM
2trux's Avatar
2trux
My running board lights quit working after banging them on rocks and tearing the wires off. I also found out that it's a quick way to remove the plastic cover.
Bugzilla46310
Aftermarket Products
Jan 26, 2016 08:47 AM
ZEALOUS_DRAGON
Jul 2, 2015 09:53 AM
HADESWRAITH
Apr 30, 2013 08:25 AM
SD-Dude
Feb 13, 2010 08:54 PM
ugotkern
Aug 23, 2005 06:51 AM
