air bag light from hell
Old Aug 2, 2004 | 09:06 PM
Jenkins6586's Avatar
Jenkins6586
i have a 1994 f-150 the air bag light keeps going on and off some times it blinks fast some times slow then theres times its on for like a 1/2 hr stright all the wires are good im really close to ripping the wheel off and putting on a aftermarket on has any one eles have this problem if so how did u fix it
Old Aug 3, 2004 | 06:40 PM
sandrat's Avatar
sandrat
It's sending a trouble code. When there is an error in the system, the computer records it, and causes the light to blink, indicating an error. Have the code read at a shop, dealership or AutoZone will run them for free.
Old Aug 3, 2004 | 07:13 PM
HighTop Van's Avatar
HighTop Van
Jenkins6586, Try to see if there is a pattern to the flashing. Mine flashes 4 times with a 1 second break and then 4 more times and a 6 second break before starting over again. That code is 44 or, the right frame mounted sensor. If you can discern a code I can look it up for you.
Old Aug 3, 2004 | 07:31 PM
LUMBERMAN's Avatar
LUMBERMAN
I DONT KNOW IF THE 99 F250 SUPER DUTY EXTCAB IS THE SAme setup if so the air bag light on my dash was due to the passenger side airbag shutoff switch was no good. IT WAS A STEADY LIGHT THOUGH NOT FLASHING.
Old Aug 3, 2004 | 07:51 PM
HomerWinzlow's Avatar
HomerWinzlow
94 doesnt have a passenger airbag deactivation switch, or a passenger air bag.
Most common fault on these is a code 32, for a bad clockspring.
Count the flashes and let us know.
Old Aug 3, 2004 | 10:05 PM
Jenkins6586
3 blinks then 2 blinks 32 it is. now what is it ,how do i fix it ,and can it cause the bag to go off
Old Aug 3, 2004 | 11:33 PM
pfogle's Avatar
pfogle
No it cannot cause the bag to go off, it's a dealer only part, and will run somewhere between 60 and 80 us dollars. It's under the sterring wheel, mine went bad, and now the rest of the plastic is getting ground up, and the contacts are shorting when I turn the wheel causing the horn to go off.
Zacw52
1997 - 2003 F150
Dec 2, 2010 02:23 PM
pablocruz69
Apr 24, 2007 07:21 PM
whtevr
2004 - 2008 F150
Jun 21, 2006 03:50 PM
Scrapiron66
Jan 12, 2006 11:48 PM
deanscheidt
1997 - 2003 F150
Dec 27, 2005 09:58 AM
