Locating Brake Control Wiring Harness in '02 Ex
Old Oct 2, 2005 | 09:38 PM
Bigfoot151's Avatar
Bigfoot151
I recently purchased a 2002 7.3L PSD Excursion and I also purchased a Prodigy brake controller along with the Prodigy-Ford wiring harness connector, but I cannot locate the plug under the dash. Can anyone offer assistance to find this plug?
Old Oct 2, 2005 | 10:02 PM
bmenzel's Avatar
bmenzel
Brake plug
I BELIEVE YOU WILL FIND THE PLUG ABOUT 6" BELOW THE THE LEFT SIDE OF THE RADIO TO THE RIGHT OF THE UNDER DASH BRACE. IT IS HARD TO FIND BUT AT LEAST THE CONNECTION FACES TOWARDS THE REAR OF THE TRUCK.
Old Oct 3, 2005 | 02:02 AM
CUINAK's Avatar
CUINAK
Post Prodigy Brake Controller Installation
Following link in the CUINAK gallery provides several thumbnail photos and instruction for the Prodigy Brake Controller connection and installation using the OEM harness.
Good luck!
CUINAK
https://www.ford-trucks.com/user_gal...&albumid=18262
Old Oct 3, 2005 | 06:36 PM
Bigfoot151's Avatar
Bigfoot151
CUINAK, Thank you so much for the pictures of the location of the brake controller plug! After I took off the fuse panel cover tonight I located it immediately. It is now plugged in, but I need to get some velcro to connect the Prodigy bracket to the dash without drilling holes. I hope I can locate velcro of approximately the same color as the dash so when I remove the Prodigy and the bracket it will be hardly noticeable.
Old Oct 4, 2005 | 08:13 PM
ExcursionMan's Avatar
ExcursionMan
I also had a fun time locating the plug under the dash. I was able to mount my Prodigy brake controller in the cubby hole above the indentation and put my CB in that place. Now they are both in a handy location.
Old Oct 5, 2005 | 10:46 AM
78crewcabjohn's Avatar
78crewcabjohn
I used an existing screw under the dash and only drilled one hole to mount my brake controller JOHN
Old Oct 5, 2005 | 11:45 AM
Mud Doc's Avatar
Mud Doc
If you use velcro, the piece stuck to the dash will sometimes come loose if you leave the truck closed up in sunlight and it heats the interior. Suggest you find to screw already under the dash like 78crewcabjohn says. My controller is mounted on the right side of the dash in my 350 using an existing screw.
Old Oct 5, 2005 | 12:15 PM
Downsized2X's Avatar
Downsized2X
Diesel User
Use Superlock velcro
Use the clear Superlock velcro from Radio Shack, catalog# 64-2363. This stuff is super strong! When you remove it, you should use a plastic putty knife to separate without damaging the velcro, this will also help from pulling the dash panel off! Both sides are the same, there is not a hook or loop side, each side is both. They are shaped more like Broccoli, so there isn't a major hair attraction. When it comes time to peel it off, it will. I have velcro'd a large boat compass to my dash as well as CD players and other large items, this stuff really works!
Old May 23, 2006 | 08:57 PM
easterisland's Avatar
easterisland
Thanks for the pictures. I was looking around in there for 1/2 hour before I thought to check the forum and get some real help. It took me 2 seconds to locate the plug. It is about 6 inches behind the pedal adjustment buttun on my excursion if that helps anyone.
rjniles
All Things Towing
15
Dec 1, 2016 09:45 AM
stephenson
Nov 8, 2016 06:29 AM
norfolknova
2009 - 2014 F150
Jun 24, 2015 09:52 PM
BlueDog
Aug 13, 2007 08:34 AM
damone
All Things Towing
Oct 19, 2004 09:45 AM
