2001 Excursion Wiring Brake Controller
Old Oct 14, 2004 | 10:29 PM
damone's Avatar
damone
I got a 2001 Excursion Diesel 4x4 w/ tow package.
I have a prodigy controller and the factory Ford harness was cut leaving just 5 wires. Blue, Black, Red, White and Whitew/ Blue Stripe.
I connected all except white w/blue stripe.
Checked all fuses & relays and they are good.
No power to prodigy.
Looked in engine compartment and saw same 4 wires I hooked up in cab. They were all cut also. They were next to fuse box and running down towards box. I exposed wiring harness to see if the other end was there somewhere & they were not. So I took Prodigy out of cab and hardwired directly in engine compartment to same four wire running to fuse box. Nothing.
What do I do know? Got truck yesterday and of course sceduled to leave at 8am. I'm screwed. Any help?
Thanks,
D
Old Oct 16, 2004 | 01:21 AM
Steina's Avatar
Steina
CO River Rat
The black wire in the Ford harness is for running lamps, and isn't used with the Prodigy. USUALLY, blue is power to trailer brake connector; red is signal from brake light switch; white is ground; and white/blue is 12V power to the controller. You might wanna check this with a tester before rewiring.
Steve
Old Oct 19, 2004 | 09:45 AM
damone's Avatar
damone
Thanks,
Took another panel off and after hardiwiring three times found the plug. Whallah.
Sunline Fan
Aug 23, 2022 06:13 AM
autox65
Jul 27, 2016 03:55 PM
Roscoe316
Jan 25, 2014 11:04 PM
BlueDog
Aug 13, 2007 08:34 AM
jlegge007
24
Jul 17, 2007 08:28 PM
