Trans Cooler
Old Oct 1, 2005 | 05:05 PM
watermanh's Avatar
watermanh
Trans Cooler
I'm looking to install a larger cooler. A recommendation from a local trans shop here (they do my trans servicing) was to delete the radiator portion of the cooler line and route through the trans cooler only. Mech says that the motor coolant is much higher temp. than trans temp. should be, only allowing heating instead of cooling of the trans fluid. Any thoughts would be greatly appreciated, aloha.
Old Oct 1, 2005 | 05:28 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
With you living in Hawaii I would agree. For those theat experience an actual winter, I think I would plumb the aux cooler after the stock cooler. That way one could use the heat of the colant to warm the tranny fluid.
Old Oct 1, 2005 | 07:52 PM
Casey's Avatar
Casey
Your mechanic doesn't know what he's talking about. Ford does not install a trans fluid heater anywhere in the truck. There are two coolers, and one of them is in the radiator.
The cooler is in the cool side of the radiator. That's the side where the coolant has already given up it's heat. That side can be quite a bit cooler than the engine temp. Without the radiator cooler you need A LOT more aux cooling or you'll overheat the trans.
Old Oct 1, 2005 | 08:18 PM
willbd's Avatar
willbd
Casey,
I think he wants to install a large cooler bypassing the on in the bottom of the radiator.
Bryan
Old Oct 1, 2005 | 08:56 PM
watermanh's Avatar
watermanh
Thanks for the replies guys. Yeah cookie thats what I was thinking. Our winters get to around 65 degrees (then we start putting on jacks!). I was gonna delete both radiator and stock trans coolers and install a RV cooler that's slightly bigger than Tru cools 3749. Thanks again and aloha.
Old Oct 2, 2005 | 01:00 PM
Casey's Avatar
Casey
Originally Posted by willbd
Casey,
Bryan
That's what the note says. I'm saying that it is a bad idea, unless overheating the transmission is the goal.
Old Oct 2, 2005 | 02:13 PM
DaBigTow's Avatar
DaBigTow
My first attempt to run with only an aux cooler (26k GVW) resulted in a trans temp far north of 300 degrees on the first major hill I pulled, with a subsequent waste of $100 worth of synthetic fluid. I reconnected the radiator tank cooler. Now I've eliminated the tank cooler by adding a 2nd 26k aux cooler. Pulling 8k at 90 degrees ambient on the level gives me 140-150 degrees trans temp. Idling thru gridlock at 90 degrees gives me almost 200 degrees trans temp. The next mod will include a valve that allows me to route thru the tank cooler in the winter and a fan in front of one of the aux coolers for extra airflow needed when sitting in traffic or pulling long hills at low speeds.
Old Oct 4, 2005 | 11:17 AM
watermanh's Avatar
watermanh
Thanks for all the replies guys! I got a 28k GVW cooler. This is what I'm gonna do: I will install to include tank, but remove stock trans. cooler. I will run it for a week or two then I'll re-route to eliminate tank and see what results are and post it. Not difficult to do and would be good information for all of us to have. I will keep you posted, aloha.
Old Oct 4, 2005 | 09:04 PM
cookie88's Avatar
cookie88
FTE Emeritus
Good plan. Maybe even run it with all three?
I'll look forward to that thread.
Old Oct 4, 2005 | 10:16 PM
lukecline's Avatar
lukecline
my trans guy specifically told me to leave lines into radiator trans cooler then to external cooler and back to tranny. my trans runs nearly 30* cooler this way.
luke
Old Oct 5, 2005 | 05:19 AM
rockyrider's Avatar
rockyrider
Leave the OEM cooler in place and add your 28k inline.
Old Oct 5, 2005 | 08:08 AM
Kwikkordead's Avatar
Kwikkordead
Let me add my vote to leave the factory cooler connected. Water is a MUCH better conductor of heat than air. You'll lose a lot of cooling capacity by disconnecting it.
Old Oct 15, 2005 | 08:39 PM
watermanh's Avatar
watermanh
OK update. Installed the 28k cooler in place of stock cooler, with tank still in-line. Unloaded:150-165 degrees depending on freeway or city traffic. Deleted tank 3 days ago, unloaded:140-155 degrees depending on freeway or city traffic. Ambient temp. 87-89 degrees. This is my daily driver, pulls a trailer maybe once a month. Thanks guys, aloha.
85camaroman
Dec 22, 2008 09:12 AM
jfboy
Sep 3, 2007 10:04 PM
mjsparky363
Apr 29, 2007 07:55 PM
redave
Dec 17, 2006 09:19 AM
