Automatic transmission cooler questions
Old Dec 21, 2008 | 10:09 PM
85camaroman's Avatar
85camaroman
hey everyone i got a few questions, as i just put a new remanufactured 4r70w trans in my 95 f150 and since i had so many problems with my original trans im also putting an autometer gauge in to monitor fluid temp. but my question is im going to eliminate the cooler lines going to the stock cooler and radiator and just run new lines to two (2) aftermarket trans coolers that i have mounted on the front of the a/c condensor. my question is is it ok to run two aftermarket trans coolers in line with each other? will it cause restriction or low flow on the trans pump?reason i wanna run 2 coolers inline is because they are relitively small only 6"x11" and 3/4" thick
Old Dec 21, 2008 | 10:18 PM
Old93junk's Avatar
Old93junk
Do not bypass the rad. cooler it serves its function well. Only 1 external cooler is needed, over cooling causes problems of its own. Unless your towing 11,000 lbs across death valley in summer, 2 ext coolers is overkill.
Old Dec 21, 2008 | 10:29 PM
85camaroman
well im running a larger non stock radiator now that doesnt have ports for a trans cooler. so would running 2 coolers be safe and ok?
Old Dec 21, 2008 | 10:35 PM
Old93junk's Avatar
Old93junk
In that case, I would see no harm. Restriction is minimal. Did you have a stock " stacked plates" external cooler originally?.
Old Dec 22, 2008 | 12:25 AM
quaddriver's Avatar
quaddriver
there is a guy on here who used to engineer trannies for ford and can prolly give you the btu requirements....but I would say you REALLY need the water/oil cooler - it does most of the work.
Old Dec 22, 2008 | 08:53 AM
85camaroman
yeah originaly the truck ran fluid through the radiator then out to a factory external cooler mounted in front of the condenser. only problem was i switched radiators so i cant run fluid through it no more and the factory external cooler was very tiny. so i figured (2) 6x11" externals could substitute and then some for proper cooling
Old Dec 22, 2008 | 09:12 AM
Old93junk's Avatar
Old93junk
Id be careful about towing or hauling heavy loads with that set up, QuadDriver is correct, the radiator cooler does remove the most heat.
lud04X
Aug 15, 2016 09:21 AM
geek guy
Jun 6, 2014 08:02 AM
1998F150XLT
1997 - 2003 F150
Jun 13, 2013 12:42 PM
Leichardti
Feb 15, 2013 04:42 PM
rufushusky
Escape & Escape Hybrid
Feb 21, 2012 06:39 PM
