Hello fellow ford enthusiests, I have a question about my 1997 F150. I recently picked up this truck and the previous owner said the check engine light has been on for a while and was'nt sure why. I borrowed a code reader from a friend and the code came up #1537-intake manifold runner stuck open...Has anyone else seen or heard of this problem and if there is an easy fix or a job for an experienced mechanic. Thanks
All I can tell you is it is bank 1, and thats from a search I did for your code. Here's where I found that: http://tazcobra.com/obd2_dtc.pdf
It's a list of codes from Ford's Diagonostics Department.
My suggestion would be to get a can of injector cleaner from somebody. My brother-in-law works for Wynn's. I get all kinds of stuff for free from him. It's stuff they use in shops. I would get a can of Fuel Injector Cleaner and a 2 cans of Power Boost. That should clean it right up. I would imagine you have some crap in your fuel rail that needs cleaned out. But I am no mchanic so, I may be giving you bad advice.
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
…Enjoy FTE and The State Chapters are located at the bottom of the main forum page. JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
