22 code on 91 Explorer
Old Jun 8, 2004 | 08:41 PM
Acooljt's Avatar
Acooljt
I have the 22 code "Manifold Absolute/Baro Pressure sensor out of range" on in my 91 Explorer. The check engine light has been coming on so I checked codes and that's what came up. Any help?
Old Jun 8, 2004 | 09:42 PM
thelonerangerxlt's Avatar
thelonerangerxlt
I'm not sure which you have on a 91, BAP or MAP? If there's a vacuum hose going to it, make sure the hose is firmly connected, and not loose or cracked. Be sure to check the other end where it attaches to the intake manifold or vacuum "tree". The BAP/MAP sensor should be located on the firewall.
Old Jun 8, 2004 | 09:54 PM
Acooljt's Avatar
Acooljt
What does BAP stand for? Also, I believe it's MAP anyway(not sure though). What hose do you speak of?
Old Jun 8, 2004 | 11:29 PM
mrshorty's Avatar
mrshorty
MAP=Manifold Air Pressure sensor
BAP=Barometric Air Pressure sensor.
They're essentially the same sensor, MAP connects to engine vacuum, BAP is just left open to the air under the hood. In the case of a '91 Explorer, it will be a BAP. I hear it's usually bolted to the firewall, though, in other cases, it's built into the MAF (Mass Air Flow sensor).
Old Jun 9, 2004 | 10:21 AM
Acooljt's Avatar
Acooljt
I'd hate to be an annoying little b@astard here, but I can't find any bad vacuum connections, but then again, I can't find the BAP sensor!
Walston
Feb 3, 2007 09:31 PM
MemOrex
27
Oct 2, 2005 07:55 AM
rbraxton17
Aug 9, 2005 11:06 AM
Bagheera
Jun 3, 2003 08:49 PM
dano14
Mar 15, 2002 05:36 PM
