'71 F100 reverse lights
Old Sep 29, 2005 | 03:25 PM
BrookHalvorson's Avatar
BrookHalvorson
My '71 F100 reverse lights are constantly on, whenever the motor is on. It doesn't matter if I'm in 1st, 2nd, 3rd, neutral, or Reverse, the whitel lights are on. I've got 3 on the tree manual. Where should I look to fix this problem? Any ideas? Thanks!
Brook
Old Sep 29, 2005 | 03:35 PM
bertha66's Avatar
bertha66
There should be a back-up light switch onthe trans, looks kind the like the brake light switch on the brake MC.
Old Sep 29, 2005 | 09:27 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Brook
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
…Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Sep 29, 2005 | 10:20 PM
durk's Avatar
durk
look at the end of the column in the engine compartment. There is a little switch. It is probably stuck in the on position.
Old Sep 30, 2005 | 01:16 AM
GregTruck's Avatar
GregTruck
There is no backup light switch on the transmission. Durk has it right I believe. It should be somewhere on the column. My 65 has the switch where Durk mentions but it has always puzzled me because the truck never had any backup lights. No need for a switch. Ford probably put the switch on all columns regardless of how the truck would be equipped.
Old Sep 30, 2005 | 07:37 AM
rebocardo's Avatar
rebocardo
FWIW: With my 1971 F-100 390/NP435/4x4/floor shift the reverse lamp switch is on the transmission, left hand side, two prong plug. A harness goes from that to a harness on the left fender near the firewall.
Old Sep 30, 2005 | 03:28 PM
BrookHalvorson
Yes, Greg and Durk are right. The reverse switch was on the column, and the button was stuck in the on position. Unfortunately, the return spring, or whatever return mechanism was there, has disappeared, and so it's stuck in the on position. The button will slide in and out, but there's nothing to make it slide out once it's depressed, hence it's stuck in the on position. Gotta get a new switch, or find a spring that works. LMC sells a switch for $15, but it says it's for a 4-spd. I'll try to make mine work first...
Thanks, guys, for your help!
PS I didn't know reverse lights were an option, GregTruck! That's strange!
Old Sep 30, 2005 | 03:31 PM
BrookHalvorson
PPS Bertha, I thought I was going crazy because I looked on the tranny first, couldn't find a thing and I got real dirty in the process. That's were I've always seen reverse switches before, and when I couldn't find it there, I came here first.
Old Sep 30, 2005 | 04:33 PM
bertha66's Avatar
bertha66
Yep, I forgot that the trans I was looking at was a 78, and it is on the trans. Sorry
Old Oct 1, 2005 | 09:39 PM
JMO6868's Avatar
JMO6868
Anyone know where this switch is on a '72 F-100/ 390/ C-7?
My backup lights were working fine before I had eng/ trans replaced.
Old Oct 2, 2005 | 07:00 AM
IB Tim's Avatar
IB Tim
Welcome JM0868...to FTE
Old Oct 4, 2005 | 01:05 AM
JMO6868's Avatar
JMO6868
Good news!
I found the switch, on steering column. Contacts were shot, so off to the junkyard, found one in good shape on a '73. Backup lights are working fine.
ceetwarrior
25
Nov 27, 2022 08:43 PM
maine71f100
17
Feb 1, 2017 02:08 PM
Seanosu
Mar 7, 2016 09:59 PM
77f2504by4
22
Nov 19, 2015 05:31 PM
JRD761
Electrical Systems/Wiring
May 11, 2015 02:11 PM
