2005 Dome light door switch
Old Sep 29, 2005 | 07:18 AM
Andywk's Avatar
Andywk
Does anybody know what controls the dome light in a 2005 ranger? I have looked around the door and thee is nothing visible. I was just wondering what controls it.
Thanks
Old Sep 29, 2005 | 08:30 AM
jimw411's Avatar
jimw411
Its inside the door latch mechanism. You'll have to pull the door panel to access it.
Old Sep 29, 2005 | 08:32 AM
Rockledge's Avatar
Rockledge
If you are having problems with the dome light staying on, it's a common problem with Fords. Try spraying some electrical contact cleaner (some people use WD-40) inside the door latch where the switch is located.
Old Sep 29, 2005 | 08:44 AM
Andywk's Avatar
Andywk
Thanks for the info. I kept looking for a button that the door pushed in. Nice to know.
Old Sep 29, 2005 | 08:59 AM
Rockledge's Avatar
Rockledge
Originally Posted by Andywk
...I kept looking for a button that the door pushed in.
Ah, the good 'ol days...
Old Sep 30, 2005 | 05:55 AM
pawpaw's Avatar
pawpaw
Just a thought, be sure the instrument pannel dim switch hasn't been pushed up & clicked into the "ON" position, as this will also keep the dome light on!!!!
Also check the " Misc." section at the bottom of the "Technical Thread" located at the top of this forums main page, for a link to more helpful info on the subject!!!!
Let us know how you do.
Old Oct 1, 2005 | 07:26 AM
pawpaw's Avatar
pawpaw
Andy, after re-reading your initial post, I realized you have a 05 Ranger & this puppy has a 3/36 bumper to bumper warranty that you just paid big bucks for, so if your having problems with the dome light staying on thats not operator error, I'd make this a Dealer/Ford problem & let them sort ths out!!!!
Old Oct 1, 2005 | 11:43 AM
Andywk's Avatar
Andywk
I am not going to be by the dealer for a few days. I just sprayed some contact cleaner in there and it is now working again. I do plan on stoping by the dealer in a few days to talk to them about it. I just needed to get the light off so I don't end up with a dead battery in the meantime.
Thank you all.
Old Oct 2, 2005 | 08:36 AM
jimw411's Avatar
jimw411
If you already solved them problem dont even go to the dealer. They will make you leave it there all day to let you knoe there was no problem found. If it does it again, just put up with it and take it to the dealer then.
Old Oct 2, 2005 | 12:55 PM
Andywk's Avatar
Andywk
I don't plan on leaving it there. I am just going to stop by and tell them and hopefully get it on record that it is happening for any future problems. As long as it works okay they won't get it!!
Old Oct 2, 2005 | 06:08 PM
arkitekt1's Avatar
arkitekt1
This is good information. The switch on the driver's door of my '03 did that a couple of times a few days after I bought it and then started working fine all by itself and hasn't acted up since. I bought the truck new, and I've always been suspicious of it. Possibly because I couldn't find the pushbutton either.
Old Oct 3, 2005 | 12:12 AM
amish_dan's Avatar
amish_dan
about that warrenty thing. make them fix it!!! i bought a 99 in 02 and 2 days down the road that same switch stoped working. has not worked consistantly since and that dealer wouldn't fix it. so if they will do somthing about it get it fixed!
Old Jun 1, 2009 | 07:04 PM
Rockledge's Avatar
Rockledge
Try spraying some electrical contact cleaner (WD-40 will work) inside the door latch where the switch is located.
Old Jun 1, 2009 | 09:53 PM
98SurplusExpy's Avatar
98SurplusExpy
Eh ... check the date of the last post ....
Old Jun 1, 2009 | 10:00 PM
Rockledge's Avatar
Rockledge
I posted in this old thread by mistake. HERE is the current thread.
Doubleubar
Feb 24, 2016 06:33 AM
Wisconsinford
Mar 19, 2014 08:31 PM
Keny1
Mar 6, 2014 02:37 PM
Spikebox
6.7L Power Stroke Diesel
Oct 11, 2011 01:42 AM
Sedric
Jan 5, 2003 11:06 PM
