General Automotive Discussion
The Differences In Platinum Plugs??
Old Sep 28, 2005 | 10:06 AM
holland501's Avatar
holland501
I just replaced the plugs in my 99 Sable. The plugs listed for it were AGSF32FM. The ones that came out were AWSF32PG in the rear(toward the firewall) and AWSF32P in the front bank. Why two different plugs? Also, the front bank had a much larger gap, about .070, while the rear bank was only about .055. I know these were worn plugs but were they gaped different to start with or did they wear at a different rate? I went ahead and changed them because it was my only transportation at the time and it seems to run fine. I'm just curious. Thanks in advance for any info.
Old Sep 28, 2005 | 10:45 AM
Rockledge's Avatar
Rockledge
You can get a pretty good idea of the what the "FM" series plugs are about, and how they are different from the conventional double platinums ("DP") plugs, by reading through this:
http://www.v8sho.com/SHO/SparkplugDesign.htm
I want to point out that most of the nuts and bolts information regarding the FM "fine wire" plug design set forth in the above is courtesy of Bob Ayers, our fellow FTE member, who is the person who actually went to SEMA and talked to the Motorcraft reps, and then followed up with their engineers, about the FM series plugs. I had quoted some of Bob's corrospendence (to me) about the subject over at another SHO-related site several months ago, and apparently the interest in the subject was so great that the people over at the V8SHO site thought it would be a good idea if the same information were passed along to the entire V8 SHO community! Fortunately, information that is good and credible has a tendency of getting around to these types of forums. Thanks again Bob!
As for the question regarding different part numbers of the original plugs, it's easier to just quote Bob from another thread wherein he answered the same question:
Originally Posted by Bob Ayers
...One thing to notice, however. If you pay close attention to
the OEM Motorcraft plugs, they are single platinum!! But,
the plugs in one bank have a different letter suffix in the P/N than the
plugs in the other bank. This is because the outer electrode is
platinum on one plug P/N, while the center electrode is platinum
in the other plug P/N.....So, if the plugs are pulled, and
re-installed, it's important to put the plugs back into the same
bank that they came out of.....
The reason why the elctrodes erode differently is due to the "waste spark" design of the Ford DIS/EDIS ignition systems.
dwildmanj
1983 - 2012 Ranger & B-Series
Aug 19, 2020 07:17 PM
dwill49965
Aug 26, 2009 03:40 PM
gulf pilot
Jun 5, 2008 03:48 PM
gwuister
Aug 9, 2007 04:22 PM
fejetmech
1997 - 2003 F150
Apr 17, 2003 08:47 PM
