2WD, 4.0L, Ranger w/AC. I smell coolant with the vent on, so I know that the heater core is bad. My Chiltons manual tells me to pull the core from the engine side. AC hoses and evaporator are definetly in the way, I don't want to break the AC system. I dropped glove box, looks like the whole dash has to come out. Somebody help me. Tell me I'm wrong.
How big a headache is this going to be. Any advise would be helpful.
Allow the engine (6007) to cool. Following all safety precautions (refer to Section 03-03 ) and using a thick cloth, turn radiator cap slowly to the first stop. Step back while pressure is released. When the pressure has been released, tighten the radiator cap on the radiator.
Disconnect the heater water hoses (18472) from the heater core (18476) and plug the heater water hoses.
In the passenger compartment, remove the instrument panel (04320). Refer to Section 01-12 .
Remove heater air plenum chamber (18471). Refer to Removal and Installation, Air Plenum Chamber and Duct in this section.
Remove heater core from heater air plenum chamber. For installation, follow removal procedures in reverse order.
