sub box in an ext cab
Old 09-25-2005, 12:23 PM
BNF861's Avatar
BNF861
BNF861 is offline
I just bought a 1992 F150 extended cab. I plan on just putting a cd player in it for now and calling it a day but you know how that goes. I may consider throwing in a sub as well but where to put it is the question? Anybody have and subs in and similar year ext cabs? The back of the rear seat is right against the back of the cab and the bottom of the seat goes right to the floor.
Old 09-30-2005, 11:58 PM
BNF861's Avatar
BNF861
BNF861 is offline
nobody with a sub in a 92-96 ext cab?
Old 10-01-2005, 03:09 AM
RomerB2's Avatar
RomerB2
RomerB2 is offline
I don't know how to help you out, I've never dealt with an extended cab F150. Are you wanting to have the rear seats functional??
Old 10-01-2005, 03:18 AM
BNF861's Avatar
BNF861
BNF861 is offline
yeah i was hoping to keep the functional but don't see a way of doing so
Old 10-01-2005, 03:33 AM
RomerB2's Avatar
RomerB2
RomerB2 is offline
I don't know how, from what I've been told. The only think I know you could do for a sub is a powered subwoofer and hide it under the passenger's or driver's seat.
Old 10-01-2005, 07:21 AM
Bargod's Avatar
Bargod
Bargod is offline
Without having that year of truck in front of me, I am a little in the dark, do the seats go all the way to the floor or are they on some sort of framework?
Old 10-01-2005, 12:56 PM
BNF861's Avatar
BNF861
BNF861 is offline
not sure just bought the truck haven't taken the lower seat out to inspect yet.Was hoping maybe someone has already. i don't want to just have a sub box sitting out in the open on the rear seat or floor. would be nice if i could fit a 10 or even an 8 under the rear seat. have to check though if its frame work or what in there
Old 10-01-2005, 01:21 PM
gravity0u812's Avatar
gravity0u812
gravity0u812 is offline
subs
you can get a enclosure made so the seat bottom is attatched to the top of the box you can fit up to 2 10 inch subs in it depending on the formula for your truck and also mount the amps in the box so the more you use the cooler it gets they also can make your seats out od accoustic material so the base fires right through them either way just go and ask a best buy or circuit city about it and they will show you or u can buy a box custom built and installed for bout 200 bucks capreted n everything with a nice warranty i have this in mybronco right now works well good luck dan
Old 10-01-2005, 04:30 PM
Bargod's Avatar
Bargod
Bargod is offline
I have one 12 under the rear seat in my 97. We did away with the frame work and mounted the seats to the box. The design seems to work pretty well, you just need to find a way to secure the box to the floor for safety reasons. We are in that process right now since we just built the box. As stated above, there are a lot of ways that you can accomplish this, just look fot the best fit for you. Holler if you have any other questions.
Old 10-01-2005, 06:01 PM
maticuno's Avatar
maticuno
maticuno is offline
I was considering buying your year of truck before I found my 99. What I was going to do had I gotten the 95 I was looking at was sacrifice the center rear seat and build a sub box/center console that sat on the floor. The center seat would no longer have leg room, but you could fit a 10" or a 12" sub in there plus you could put cup holders and such on the top of the box for your rear seat passengers.
Old 10-08-2005, 08:18 PM
Biglame's Avatar
Biglame
Biglame is offline
Ford hasn't left you with many options for a sub in the extended cab, especially if you want complete function of the back seat or a factory look. If you have bucket seats in the front, you can build a box that will elevate the center console about 6 inches (just lower than the factory armrests). This gives you enough room to build an enclosure for a 10" or 8". If you plan it out and take your time you can make it all look pretty close to something from the factory, especially if you encorperate cupholders or map pockets into the enclosure, and cover it with the same color carpet as the floor.
If you are really fiberglass savy, you could mold the enclosure right into the console and then it would essentially be one piece. There are some other options, but the rest require extensive modification and fabrication. I am currently in the process of building an complete stereo including an enclosure for my 1994 f250 extended cab at my shop. When it is complete, I will post some pictures.
1997jerry
08-05-2015 11:50 PM
BrassMonkey
1997 - 2003 F150
19
04-16-2011 04:04 PM
1957F100
05-24-2008 10:51 PM
ramrod7373
02-03-2007 02:38 PM
rwb
07-18-2001 05:29 AM
Quick Reply: sub box in an ext cab
