OD issues
Old Mar 23, 2014 | 06:44 AM
Motsch788's Avatar
Motsch788
OD issues
Good morning y'all,
I have a 94 f-350 7.5l E4OD, 34,000 miles on it.
I am pulling the transmission today to replace/update the leaky front shaft seal. I have another issue in which every once in a while it neutral drops while in OD. It only does it in OD, and it doesn't matter if it is under load or not. It comes out of gear for about 1/2 a second, just long enough for me to notice it when it SLAMS back into gear. Fluid level is and always is good, a fluid flush did not fix. Always shifts great otherwise. Any idea what this could be while I have the fluid out of it?
Old Mar 23, 2014 | 07:54 AM
subford's Avatar
subford
Sounds like a bad TR sensor.
If it was 4X4 it could also be it has the wrong filter in it. If you put a 2 wheel drive filter in a 4X4 transmission with a deep pan it will do this also.
But most of the time it is the TR sensor and make sure you aline the TR sensor in neutral with the marks on it.
Note that the auto parts stores will call the TR sensor a neutral safety switch.
Old Mar 23, 2014 | 08:41 AM
mrrish79's Avatar
mrrish79
It's also called a manual lever position sensor MLPS the dealer calls it a transmission range sensor. This truck only has 34k on it?!
Old Mar 23, 2014 | 09:11 AM
Motsch788's Avatar
Motsch788
Thanks guys. I know it has the right 4x4 filter in it, I will put a new switch in and see if it helps.
It was a fire truck, that's why it has such low miles. Crew cab dually 4x4 water tanker that I have converted to a pickup. Its been a lot of work, but its what I've always wanted and should last me forever.
Old Mar 23, 2014 | 09:19 AM
subford's Avatar
subford
Sorry, I see the OP has a 1994.
Yes in 1994 it was called a MLPS and then the name was changed in 1995 to the TR sensor.
miked79928
1997 - 2003 F150
Sep 26, 2025 06:33 AM
trex777
2004 - 2008 F150
Jun 23, 2016 11:58 AM
jes01srw350
Jun 30, 2013 09:23 AM
Jitterbug
Ontario Chapter
Dec 23, 2009 03:10 PM
DarylZ
16
Nov 26, 2007 08:19 PM
