Sponsored by: Auxito
fun poll: how many miles?
Old Sep 24, 2005 | 09:59 AM
kmoss69's Avatar
kmoss69
ive got a 99 fi50 4.2 v6 with 240,000 miles on it. i take it easy on it, and do all maintanence myself. all ive had to do is replace the alternator once and the font rotors once. any one else been so lucky?(knock on wood) this is the 1st ford ive ever owned, used to drive s-10s.i think i will be a ford man forever now.
Old Sep 24, 2005 | 11:05 AM
Patatoe1's Avatar
Patatoe1
240,000 in 6 years?!?
Wow I thought I had a lot with 86,000 on a 2001.
Old Sep 24, 2005 | 01:03 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I just got my '97 XLT 4x4 4.6L, auto, with 80,000 miles on it 3-4 weeks ago (to the day actually). The previous owner replaced the ball-joints, calipers and rotors. Installed 32" Winston Winner LT tires on the optional aluminum 6-spoke wheels.
He has had a seat cover, floor mats, and a bedliner in it the week he drove it off the dealership lot.
He has kept records of every oil change, tranny flush, air filters....everything he's put into the truck.
Old Sep 24, 2005 | 01:09 PM
ddrumman2004's Avatar
ddrumman2004
My 97 Lariat with 4.6 auto has 150k+ miles on it now. I have had it 4 years and all I have done is had new lower ball joints installed and the front brake rotors turned.
This truck runs a good now as when I bought it. People are surprised when I tell them it's an 8 year old truck because it looks so good. Whoever owned it before me took great care of it.
Old Sep 24, 2005 | 01:17 PM
bigdaddyII's Avatar
bigdaddyII
I have a 97 with 187,000 miles. Fixing to replace the clutch for the second time and had to replace ball joints rotors, shocks and heater core. The rest is routine maitnance.
Old Sep 24, 2005 | 03:25 PM
triton_2002's Avatar
triton_2002
2002 supercrew xlt with the 5.4, bought it with 19k, now have 45k. Nothing but oil changes, filters and gas......lots of gas!
Old Sep 24, 2005 | 03:56 PM
Patatoe1's Avatar
Patatoe1
Can I do that. I know that one of my front rotors is warped a little bit. People that I have talked to though said that i would half to turn both fronts and replace the pads too. Can I just turn the rotors?
Old Sep 24, 2005 | 05:21 PM
bigdaddyII's Avatar
bigdaddyII
Heat is what warps the rotors and heat is also bad for the brake pads, so yes, replace the pads too, they are cheap and while you have the tires and everything off would be a good time to replace them. Also, turn both rotors, if you dont you will just end up doing the other one later anyway. But for all intents and purposes, you dont HAVE to change pads and turn both rotors but no job is worth doing that is done the opposite of full slow.
Old Sep 24, 2005 | 05:30 PM
maticuno's Avatar
maticuno
Mine recently turned over 180k. I do my own maintenance. Only "major" stuff I've done since I've owned it is pads/rotors and both (pitman and idler) steering arms. Of course, the truck was bone stock when I bought it so I've done a slew of little mods here and there. Just put on some diamond cut clear headlights on. Makes it look like an '04.
Old Sep 24, 2005 | 05:51 PM
steve(ill)'s Avatar
steve(ill)
2001 SCrew 4 x 4, 5.4 liter. 130,000 miles. nothing but lower ball joints, trans filter and oil, normal maint. original spark plugs, still thinking about that.
Old Sep 24, 2005 | 07:46 PM
KreaseDemon's Avatar
KreaseDemon
Well, i think so far i have the most miles, but i'm sure someone on here has more. I've got 246,108 right now, i looked at it before i came in the house for some odd reason, and it stuck in my head. oh yea, 1997 4.6L. Runs good, prolly gonna tear somethin up on it now that i got 305/70/r16s but it'll be alright.
Old Sep 24, 2005 | 08:49 PM
Patatoe1's Avatar
Patatoe1
Do I have to do anything to the rear brakes? Or can I just let them be.
Old Sep 24, 2005 | 09:20 PM
bigdaddyII's Avatar
bigdaddyII
If they are not causing any problems, just let them be. After you take care of the fronts, if the truck still shakes when braking, the rears are the place to look.
Old Sep 24, 2005 | 09:25 PM
trent1059's Avatar
trent1059
99 F150 scab 165000 no problems
Old Sep 24, 2005 | 09:40 PM
lariat97's Avatar
lariat97
I have 118000 miles on my 97 F150. Its become a POS since it hit 100,000 miles. I hope to get rid of it soon. I can't trust it anymore.
