Mass air swap
Old Sep 22, 2005 | 12:17 PM
Lone Wolf #2's Avatar
Lone Wolf #2
Mass air swap
Sorry if this thread has already been discused and I missed it, but can anyone tell me what needs to be done to swap over to mass air. Have a friend with a 96 he is selling and is willing to swap parts.
Old Sep 22, 2005 | 12:20 PM
optikal illushun's Avatar
optikal illushun
1996 is mass air but also ODB-2. not worth it IMO. speed density gets along just fine with a re-burned custom chip.
Old Sep 22, 2005 | 12:48 PM
Silver Streak's Avatar
Silver Streak
Yep, don't waste your time and money. There will be more to it than just swapping parts. The way to do the swap would be to use the Mustang A9L PCM and convert to sequential injection. Still too much work and probably not a good idea on a daily driver.
Old Sep 22, 2005 | 12:54 PM
Lone Wolf #2
Thanks to both, just thought that if the parts were available for little cost it would be a good idea to prepair for future upgrades.
Old Sep 22, 2005 | 01:11 PM
optikal illushun
yeah, its a good idea but not feasible. i know a few people on here were trying to see if a tWeeCer would work to custom tune the EFI...but nothing came outta that.
Old Sep 22, 2005 | 01:18 PM
Motorhead351's Avatar
Motorhead351
As mentioned the 4.9 mass air isn't the holly grail as one might expect.
If your serious about upgrades, there are chip companies willing to work with you on setting up your speed density right. Last time I checked though and this wasn't long ago, a couple companies requested I sent my actual eec so they could "crack it". Unlike a crappy chip off ebay, this one wouldn't just up the timing, it would take into consideration the cam, head work, exhaust, etc. have the maps adjusted accordingly. Dyno time would be ideal.
Californina switched to mass air a couple years before the rest of the states went mass air in 96, you can go to car-parts.com and probably get a junkyard to hook you up, if thats something you wanna do.
Good luck
Old Sep 22, 2005 | 01:53 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Sep 22, 2005 | 03:12 PM
Silver Streak
Gimme some time. I've got lots going on right now and the truck has been moved to the back burner for another few months. Once I get some things taken care of I'll be right back on top of that.
Old Sep 22, 2005 | 03:13 PM
optikal illushun
oh ya, that was u...lol. i forgot who was at it even...take ur time man, no hurry.
Old Sep 22, 2005 | 05:24 PM
Motorhead351
Lone Wolf #2
Have you considered building your own efi controller?
Probably have but if not, check out the following links, the first is the least expensive and the info/ bulletin board is easy to follow, the second costs a little more (actually a spin off of the original megasquirt), the board is not as easy to follow, yet offers a couple more features (or did), as compared to the MS. Again, good luck
http://www.msefi.com/
www.vems-group.org.
Old Sep 22, 2005 | 05:41 PM
Lone Wolf #2
Not to good with electronics, so this probably isn't the best idea but thanks anyway.
Old Sep 22, 2005 | 05:53 PM
Motorhead351
Ah, at least give the first link a chance, look it over real good about 10 times, , you might be suprised how doable it is. Last I checked, a person could assemble the controller for $200 or so, then you can program it until your fingers fall off using a lap top. Suprisingly there aren't that many connections to make from the old eec to the MS contrller, there are people who've successfully ran this on a 4.9 engine, maybe if you get that interested, they may offer a base tune to get you started, possibly. You can also purchase the controller pre assembled, prices vary but they are under $500, then you make the connections from the old eec to the new controller, do a couple little things to get the MS to understand the ford sensor parameters, then your off...
Yeah, easier said than done but doable.
Jrock909
Jun 8, 2007 11:09 PM
choochoof150
Mar 15, 2007 07:16 AM
ftwfred
Dec 23, 2002 10:11 AM
John7894
Mar 6, 2002 11:24 AM
Will Stewart
Feb 11, 2002 07:49 PM
