mass air swap
Old Mar 14, 2007 | 02:46 AM
choochoof150's Avatar
choochoof150
mass air swap
can a mass air meter from a 88-93 or 94-95 mustang work on my 95 f150 5.0?
Old Mar 14, 2007 | 07:36 AM
Conanski's Avatar
Conanski
Yes, as long as you have the matching computer.
Old Mar 14, 2007 | 09:34 AM
gustang818's Avatar
gustang818
What computer are you using? If the mass air computer you have recognizes 19lb injectors you may be ok. If not, you could have a chip burned by someplace like Superchips or use a tuner like the tweecer or PMS.
Old Mar 14, 2007 | 11:55 PM
choochoof150
It is the factory 5.0l 1995 auto 2wd computer. I would have to pull the computer out to get the # off it. The plug on my C&L mass air off my 91 mustang looks the same as my 95 f150 mass air plug and sensor.
Old Mar 15, 2007 | 07:16 AM
Conanski's Avatar
Conanski
So your truck is mass air then? If so and the C&L is calibrated for 19lb injectors then yes it will work on the F150. Don't expect any performance improvements though, it may actually make low speed and idle quality worse... unless the motor in the F150 is heavily modified of course.
Plowboy34
Jun 5, 2012 07:23 AM
boosted95
Jan 26, 2011 12:07 PM
beendooben
Apr 25, 2010 08:44 PM
Jrock909
Jun 8, 2007 11:09 PM
monsters
17
Apr 15, 2005 08:30 AM
