That question has been asked a millon times - the only way is to measure the stroke. Remove a spark plug and insert a drinking straw into the cylinder. Rotate the engine until it bottoms and mark the straw against some convenient point. Then rotate the engine until the piston is at the top, mark the straw again. The differance between the marks is your stroke.
If it is 3.5" it is a 360, 3.75" is a 390.
If the engine is stock you can also tell by decoding the VIN number.
dehamma Put your money on the 360. There were a few 390s installed but about 99% of them are 360s.
***** has a good suggestion, I think it would be adding time to the job trying to get the bottom and top. I usually recommend have a friend rotate the engine while you hold a Sharpie against what you are using in the hole and just mark the whole time on a couple revs. Either way you measure the length of the mark. Whatever you use the smaller it is the better. I perfer a piece of white 14-2 house wire with a slight curve in it. It is both small and ridig.
You may have to do it more than once, but you will find a method that works for you.
Same here - thanks Jowilker, I learned something today. The next time I have my spark plugs out and help available I will give your methoid a try, sort of pound it into my head. If I've actually done it I am more apt to remember the idea.
Thanks gents, I tried the 1/4" wooden dowel and it was a pita. The wire is smaller, fairly easy to come by and simply stated works the best, at least for me.
I have seen some heated arguments settled with it. A lot of guys are in denial about the 360.
I loved the 360 in my '70 F100 when I owned it... great engine... however if I had to rebuild the engine I would go with the 390... no replacement for displacement
