helpwith 360
Old Nov 29, 2005 | 08:35 AM
460man's Avatar
460man
helpwith 360
parts i need to convert 360 to 390. any help is appreciated. i have tow 360 withone that has 390 heads i think???
Old Nov 29, 2005 | 12:19 PM
rusty70f100's Avatar
rusty70f100
We need a stickey with how to convert a 360 to a 390...
Simple version:
Anyway, you need to obtain a 390 crankshaft and a set of 390 rods. You use 360 pistons with the 390 crank and rods to get a good high compression 390.
Post the numbers off each set of head so we can tell you what you've got. Also post the block numbers. Numbers we're looking for are, for example:
Heads: D2TE-AA
Block: D3TE
Old Nov 29, 2005 | 01:01 PM
460man's Avatar
460man
360 - 390
ill check the #'s. what about the heads. do i use 360 or 390 heads. it would help if anybody had a 390 rods or even a crank that they would sell.
Old Nov 29, 2005 | 01:34 PM
rusty70f100
A great place to get your 390 crank and rods is the junkyard. There's plenty of pickup trucks (usually F250 or F350) out there that have the low compression 390's in them. Find one that doesn't have any spun bearings and go from there.
On the heads: A lot of times the 360 and 390 used the same heads. On late truck motors anyway. But get the numbers then we will know exactly what you have and what would work better.
Old Nov 29, 2005 | 02:00 PM
460man's Avatar
460man
390
ill call around and find one. thanks alot
1956in1956
Sep 14, 2013 11:51 AM
Aaronmb
26
Jan 19, 2013 09:47 AM
ColodadoFordBoys
28
Jan 23, 2009 02:46 PM
73F100*8Mile
Sep 15, 2005 09:56 PM
61 uni
Sep 30, 2004 06:33 PM
