power window motor removal
I did this once. Had to replace the gears in the motor gear box. I don't recall any real difficulties (remove panel, drill out rivits, unplug, remove) until it came time to reinstall. Ford uses those honker big pop rivets that 99% of us don't have a tool for, and that take extreme muscle to install.
I ended up at a dealer to get them put back in.
Gear kit/motor replace
I have an '89 E350 that needs to have the gear kit for the drivers electric window motor replaced. I'm confused, CHILTON says to drill out the dimples with a 1/2" bit. However when I inspected where the holes would end up, they didn't seem to line-up with any screws that CHILTON says engages the motor to the drive and regulator. You say to drill out the rivits. It looks like that would drop the whole window assembly. Is ther any way that I can pull the motor/gears without dropping the whole mess?
I have an '87 E150 van and didn't have to remove any rivets. I just bought a rebuilt motor from the parts store.
As I recall the power window/lock switch had to come out, the door handle, and some other screws. Once all that was out of the way there were 3 bolts holding the motor in place. Of course the window wants to drop down when it's removed though I don't recall it being in the way of the removal in the lowered position.
Just did mine last week , drill out the 3 rivets, unhooked window from slider held it Window up with a wooden wedge between glass an inner door frame , unplug motor wires, turn an twist an said a couple swear words pulled motor an reg. assy outta door, remove 2 small screws that hold motor to reg. an reinstall, used 3 , 1/4"by 1" machine screws an nuts with a dab of locite on the threads, Window works like
Hey Gang,
My E350 had 4 riviets, Used duct tape to hold glass in up position. Drilled out riviets. Dropped regulator gear with arm. Took apart motor/gears. Aha, the problem was the gears were chewed-up. Bought a gear kit, $22.99 from Schuck's, Replaced riviets with 1/4X1/2 #20 Stainless bolts, and the deed was done. Thanks to everyone's input.
Zig
Zig
usedtoolman
05-30-2018 06:21 AM
sparkyrhett
05-07-2007 02:21 PM
