E40d Schematic Needed
Old Sep 6, 2005 | 10:00 AM
Barrin's Avatar
Barrin
Hello,
I have an 83 Bronco 351w E40D 33bfg's in Keywest Fl.
Yesterday I was changing my fluid and filter (Yes now I know that the filter doesnt need changing) anyways when I got my tranny pan off a little plastic peice was just sitting there in the bottom of my pan. it looks like a round top with a hardened o-ring.
I took the peice out and put my pan back on and replaced the fluid and drove arround fine. its just that every now and then it slips outta gear and I have to reve up my gas peddle and when my rpms go down it picks up back in gear.
If anyone has a schematic so that I might find where it goes and put that little plastic peice back.
I will try to get pictures posted....
Thanks.
Old Sep 6, 2005 | 01:03 PM
subford's Avatar
subford
That's a dip stick hole plug. When the transmission is put in at the factory it seals the hole while assembly and when they put the filler tube in they push the plug into the transmission. You can throw it away.
They did not have a E4OD in 1983, They had a C-5, C-6 and a AOD on the Automatic Transmission side.
Old Sep 6, 2005 | 01:24 PM
Barrin's Avatar
Barrin
Thats funny...
thank you so much...
so, I have read the threads and still cant figure out what 3spd automatic that I have then....I just figured that It was an e40d.... are you shure its not... actually I think that I read it somewheares... Ill reserch it...
thank you for the refreshing news about the filler cap.. that makes sense....
Old Sep 6, 2005 | 01:58 PM
Casey's Avatar
Casey
The first year the E4OD was made was 1988. It didn't get into Broncos for a while after that.
You almost certainly have the C6.
Old Sep 6, 2005 | 04:34 PM
subford's Avatar
subford
The only Automatic Transmission in a BRONCO in 1983 was the C-6. And it would have a Code "K" under "TRANS" on the drivers door label.
Old Sep 7, 2005 | 11:52 AM
Barrin's Avatar
Barrin
Thanks guys....
Old Oct 3, 2005 | 11:03 AM
flitemedic's Avatar
flitemedic
E40d or C6?
Plus I believe that the E4OD has a fibre screen filter that you'd want to change...maybe....some say no..some say yes... and the c6 and aod have a metal mesh screen
kamloopsfordguy
Apr 5, 2013 07:45 AM
keywest
2009 - 2014 F150
Jan 1, 2013 02:42 PM
f250luis
Feb 19, 2010 04:21 AM
Mudder
Dec 30, 2006 10:54 PM
'88_F-150
Mar 15, 2005 09:04 PM
