1993 explorer transmission problems
Old Dec 10, 2006 | 03:37 PM
Mudder's Avatar
Mudder
Hi guys and gals,i have a 93 explorer and i think the transmission(A4LD) is about to go. When i go it redlines in 1st gear and wont shift into second until i stop,and put it in park then reverse then put it back into drive,then it will shift real hard into second,all the rest of the gears are shifting hard and at a higher rpm then usual,and ive 100% lost overdrive. I dropped the pan today and changed the filter,there was about a half inch peice of metal just floating around in there and the fluid was a godawful color. I changed the filter and gasket,flushed out the trans and filled it up again and its still doing the same thing,maybe shifting a tad smooth but everything is the same. Any idea if its about to explode? Or what the problem might be?
Old Dec 10, 2006 | 06:27 PM
maa139's Avatar
maa139
I have a 94 and it was starting to slip and shift hard. Needed a rebuild. From what I hear, 140K is about the life expectancy of the A4LD.
Good luck. Mine was $1500.
Old Dec 10, 2006 | 06:35 PM
aquanaut20's Avatar
aquanaut20
you waited too long, shreds of metal indicate a total rebuild, hard parts as well as soft, might even have finished the case...
Old Dec 30, 2006 | 01:12 PM
unseenspirit's Avatar
unseenspirit
Your tranny is about to go KA-PUT! Get it rebuilt, metal in the pan is a very bad thing.
Old Dec 30, 2006 | 10:54 PM
4.0 Beast's Avatar
4.0 Beast
yea, my A4LD lasted about 125k. $1500 for a rebuilt one (hard/soft parts). they just took my old one and put the new (rebuilt) one in. (cottman's)
tonfro
1983 - 2012 Ranger & B-Series
Jun 9, 2016 03:39 PM
Richard.Parker
1997 - 2003 F150
Dec 19, 2014 07:50 PM
psimon
17
Oct 1, 2010 02:29 PM
dlsmithsr
Dec 2, 2009 05:19 PM
DaveWW00
Mar 28, 2005 03:17 PM
