custom cluster panel
Old Sep 3, 2005 | 11:50 PM
captinspecial's Avatar
captinspecial
i was wondering if anybody has ever seen a custom instrument cluster panel that incorporates space for a cd player/stereo? all help is appreciated. thanks
Old Sep 4, 2005 | 01:01 AM
deisele75's Avatar
deisele75
as far as aftermarket.... no. There are a couple of guys here that have made their own. Maybe they will chime in.
Old Sep 4, 2005 | 02:05 AM
ivanribic's Avatar
ivanribic
I built a dash that could work out great for a DVD player if you wanted. I have a whole gallery on the dash prioject here: https://www.ford-trucks.com/user_gal...&albumid=12311
Old Sep 4, 2005 | 08:10 AM
MBBFord's Avatar
MBBFord
If your looking for a custom dash, you'd have to make one yourself, like Ivan.
If you just want a cd player to fit, then cut out some of the plastic on the dash molding to make one fit.
Old Sep 4, 2005 | 10:01 AM
nhswrld's Avatar
nhswrld
in addition to the plastic on the dash molding you will have to trim the metal that the old radio mounts to, where the two ***** come out
Old Sep 4, 2005 | 04:31 PM
easydoesitmikey's Avatar
easydoesitmikey
That is sweet.I am adding that to my "to do" list.
Old Sep 4, 2005 | 06:17 PM
735.0Short's Avatar
735.0Short
ivan i was thinking of doing the same thing as you with the gauges i have a question as fars as the digital spedometer goes how hard is it to conect?
Old Sep 5, 2005 | 02:29 AM
ivanribic's Avatar
ivanribic
It's EASY. I pulled the sending unit out of an 80's van ($2 at the local yard). The electronic sending unit fits right in where your speedo cable goes but has 2 wires coming out of it instead of a cable. One wire is grounded, the other runs to your speedo on the signal terminal. Then you have ignition power and that's it. You can calibrate it easily for any size tire or gear set.
Old Sep 5, 2005 | 07:31 AM
SwOkcOffRoader's Avatar
SwOkcOffRoader
hey ivan, whats that box where the ashtray was?? im about to practice making a dash on the dash in my old cab, ill do my best not to make it look better than yours ivan...
Old Sep 5, 2005 | 09:56 AM
STGFordCrazy04's Avatar
STGFordCrazy04
Thats pretty awesome Ivan. The only problem Ive found with just placing sheetmetal over the dash cluster hole is that now the gauges are facing downward slightly.
Mclaughlin has a really nice setup in his truck. Check that out
Old Sep 5, 2005 | 11:40 AM
ivanribic's Avatar
ivanribic
To solve this I built a bracket that pushes the bottom of the dash out and angles it back up toward me. There's one bolt on each side and then 2 above the steering column. If you move these you can put it at any angle you need. Of course you could also build something like I did but make the entire thing beveled so you don't have to angle your dash. Ah, I'm lazy.
The box where the ashtray used to be is a switch box off a police car. It's got 6 switches, one for flashing headlights, my lightbar, tranny cooler, aux. radiator fan, one I'll use for my compressor and I haven't decided on the last one yet. It's nice because it's compact and looks clean in there.
Old Sep 5, 2005 | 05:16 PM
735.0Short's Avatar
735.0Short
are all the sending units the same ive got the T-5 in my truck only one gauge wors so yah im looking to buy the american platinum off of summit from autometer
Old Sep 5, 2005 | 05:23 PM
ivanribic's Avatar
ivanribic
I don't know if you can use an OEM sender with an Autometer guage but typically the guages will come with their own sending units. I'm using mechanical guages for everything but my tranny temp (and speedo) as I don't trust them. I may be switching to a mechanical tranny temp guage soon too.
Old Sep 5, 2005 | 10:43 PM
mclaughlin31's Avatar
mclaughlin31
Thank you...I have some pics in my first gallery...Not as nice as Ivan's set-up but gets the job done.
Take Care
James
Old Sep 5, 2005 | 11:47 PM
ivanribic's Avatar
ivanribic
Yeah but his truck is so pretty it makes me cry so I try not to look at it. That's the best bodywork I've ever seen on one of these trucks. But you can see in his pics how he's built an angled bezel for the guage panel. This isn't hard to do but it will put the guages at an optimal angle for viewing if you want to leave the dash as is.
Jeff Watts
Apr 5, 2015 06:31 PM
ThDanMan
1978 - 1996 Big Bronco
Jan 13, 2015 08:53 PM
1981 F_100
Jan 16, 2012 08:28 PM
custom1106
Oct 20, 2011 02:47 PM
DeGideo
Apr 21, 2002 04:41 PM
