No start problem
Old Aug 30, 2005 | 11:34 AM
alexschmidt99's Avatar
alexschmidt99
No start problem
Yes, I did search. My problem is slightly different. Sometimes this problem occurs, sometimes it doesn't. There doesn't seem to be any pattern to when it occurs. The problems is I will turn the key and hear a click. Lights work fine, radio works, etc. I'll turn the truck off, and try again. Sometimes on the second try it will start up, sometimes not until the third or fourth try. It just started happening in the past couple months, becoming more and more frequent. The difference in my problem and all the others I saw posted, is that my truck will start, whereas most people said their truck wouldn't. So, I cleaned the ground points real well, and that made no difference. As I understand the next 3 culprits to examine are the battery, the starter and the fender mounted relay. Another possibility would be the ignition itself. Any tips on which one to begin with?
Old Aug 30, 2005 | 11:45 AM
andym's Avatar
andym
Very high on my list of suspects would be the starter, although the relay is so cheap, it's worth replacing anyway, even if it's just for kicks.
Old Aug 30, 2005 | 11:54 AM
quicklook2's Avatar
quicklook2
my spade plug on starter was not making good contact and caused problem like you state.
1996fordxlt
Mar 22, 2013 09:48 PM
jongirouard
Oct 15, 2007 08:00 PM
a64armt
Jun 1, 2006 07:38 PM
Jeff$ery
1983 - 2012 Ranger & B-Series
May 31, 2006 06:43 PM
clcass55
1997 - 2003 F150
Jun 29, 2005 08:00 AM
