carb worth it?
Old Aug 29, 2005 | 08:10 PM
trumpboy77's Avatar
trumpboy77
carb worth it?
I have an 84 F150 with the 300 I6 in it and just about everything under the hood is stock and I am want to get as much out of the thing as possible. what would be the pros and cons of rebuilding or getting a new carb, and would it be worth it? also if you have any suggestions keep in mind im on a tight buget, the court will be reciving most of my money for a long long time (dang diversion program may be saving my *** but it's costing me an arm and a leg)
PS. my truck is going to be sitting for 90 days so time isn't really an issue for me.
Old Aug 29, 2005 | 09:27 PM
Ford_Six's Avatar
Ford_Six
You can usually find Offenhauser intakes on Ebay for cheap, throw an adaptor and a decent 2BBL on it, and you have a pretty good intake setup. On my old 300-6, I used the exhaust manifolds from an EFI 300-6, with 2" duals, and it gave good power across the board. I used the Offey intake, first with a Holley 350cfm 2BBL, but it was hard to keep tuned, so I put on a Motorcraft 351cfm 2BBL, and never had another problem with it.
The 2" exhaust may seem small, but I also tried a 3" single, and wished I had kept the duals. I lost most of the low-end power, and gained very little if any in the upper end. I drove that truck cross-country with a trailer, grossing nearly 12,000lbs, and it did pretty well. I usually shifted it in the 5,000rpm + range, and it pulled strong through 5500rpm.
Old Aug 30, 2005 | 02:23 PM
biz4two's Avatar
biz4two
Pros and cons of either rebuilding or purchasing a new carb? Well, if you are able to rebuild it (technically inclined), then rebuild it. As long as it is rebuildable? No reason to purchase a new stock carb if you can rebuild the old one. Save the money...
JMHO...
DBGrif91
May 21, 2011 08:08 AM
boo-yaa138
Feb 20, 2010 02:06 PM
Scolesy8
19
Apr 28, 2008 09:36 PM
22mill
Feb 2, 2006 12:14 PM
jvmcc
22
Apr 4, 2005 06:59 PM
