351 info
Old Feb 1, 2006 | 03:12 PM
22mill's Avatar
22mill
351 info
hello to all out there, well i got a ford f250 a bit ago to part out, it was a 87, so i kept the engine, and the block ID says its a 84' motor, and it has E7 heads on it, and it does have a ford reman. tag on the block, its a 4v carbed motor. now does any one have any info on that engine, ie: carb info, hp ratings, stock cam lift? i am going to put it in my 70' F100 and would just like to bump up the cam a bit, maybe the summit racing one witch is .448/.472 lift and 204/214 duration, some long tube headers. is the carb worth messin with or should i get another 4v? well any info would be great, thanks
Old Feb 1, 2006 | 04:28 PM
Kemicalburns's Avatar
Kemicalburns
call compcams for a recommendation. strange that it has e7's but that would tell me that the bottem end is an 84 while the top end is from an 87. if you change cam figure on getting new springs as well
Old Feb 2, 2006 | 02:57 AM
22mill's Avatar
22mill
well the motor is a remanufactured one, so where ever the the last owner got it at prob put different year short blocks together with the same year heads. is that 4v carb anygood that is on it, can i add parts to it to make it better, like bigger acc. pump, ect.? i would like to have a good runnin motor for my 70' F100, that will cruze well. thanks for info
Old Feb 2, 2006 | 09:30 AM
DaveBowman's Avatar
DaveBowman
Just because the block says E4 doesn't mean its an 84 block. It just means 1984 was the last year a revision was made to the block.
Old Feb 2, 2006 | 12:14 PM
22mill's Avatar
22mill
well the year of the block doesnt really matter to me, i just care about the carb and puttin together a cheap motor that will run good for me
banjopicker66
May 25, 2010 10:44 PM
kidkaden
Jul 16, 2008 07:28 PM
mustange70
Oct 14, 2005 12:32 AM
BlueOvalRage
13
Mar 27, 2002 09:46 PM
